Question about Weber Q Grill
Gril will not start even though there is a full tank of gas. Did all the steps to turn on gas, then burners and then start but will not start- not even with a match.
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
Replaced tank on grill now it wont light
you can test the regulator turn gas on see if it gets cold with all burners turned on not lit clean gas burners holes with a paper clip
Aug 25, 2012 | Char-Broil Grilling
Tip
Gas Grill Won't get as hot as it used to? Read on:
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
on Mar 19, 2010 | Grilling
After replacing LP tank, will not start - I don't even hear the gas.
turn off gas on tank open gas burners , turn off gas burners turn on tanl slowly should work now .
Aug 23, 2012 | Weber Genesis Silver B Grill
WE HAVE A BRICKMAN GAS GRIL #810-8411-5 AND GAS IS NOT GETTING THRU. WE HAVE CLEANED IT OUT COMPLETELY, NOTHING IS BLOCKING ANYTHING, BUT IT STILL WON'T LITE. WHATS OUR NEXT STEP
Myra, the problem lies with the grill's gas regulator and how the tank was turned ON. Or the tank is empty.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 25, 2011 | Brinkmann 810-8410-S Stainless Steel...
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
No Gas Getting to Back Burners
sounds like you have debris in the gas regulator,remove the tank and look into hose end to see lf its clear.sometimes just tapping lightly on the reg,will release the debris.u may need to replace hose and regulator to burner assymbly.if this doesnt fix it.
Apr 13, 2010 | Weber Genesis Silver C Grill
Grill lights but flame is low and goes out if control is moved from high. Burner tube is clean, spider screen is clean, and I have a full tank of LP. Grill is Q series about 1 year old and has been working...
Mar 22, 2010 | Weber Q Grill
My burners don't put out out much of a flame. Model CGBD48RSBX. Ten years old. Can I clean them?
Hello. Clean them with a wire brush and a shop vac. And, read on: re you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
Mar 21, 2010 | Grilling
3 burner charmglow gas gril
I am replacing burners and I need to know if the burners if they go tightened or loose.
Oct 20, 2009 | Brinkmann Charmglow Stainless Steel LP...
Fuel tank shuts off long before tank is full
the vent tube that runs beside the filler hose is crimped shut or clogged
Jun 29, 2009 | 1999 Chevrolet Silverado 1500
Weber Q Grill Logo
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
