Question about John Deere Garden
I have a JD 4400 compact tractor M4WD with rock shaft problems. When raising the 3 point hitch to transport position i.e.. lever in notch, the hydraulic pump will not stop pumping or go into pressure relief. The pump dead heads under full load unless I move the rock shaft control lever down. I tried to adjust the rod on the top of rock shaft that tells the control valve it's position. This changes the location on the control lever when the shafts start to drop. Is there a pressure relief valve at the at the pump that could be bad. My front end loader does the same thing . If you hang on the control lever to dump bucket it keeps on pumping. Thanks for your help Mark
5 Suggested Answers
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
  • 8404 Answers
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Posted on Sep 25, 2009
Biggdex35
  • 333 Answers
SOURCE: Tractor Front end loader will not dump
Could be a lot of things. Quoick coupling loose? Does the lever work from left to right? Is it stuck now and only work from front to back? There is a small lockout feature on it that keeps from it moving when you hit it with your legs. It is down at the base of the lever. Other than that has to be connections. Try swithching the hoses around where up and down is dump.
See if its that
Posted on May 11, 2010
  • 146 Answers
SOURCE: JD 3320 tractor with error code 57
From what I can find, that is a 'timeout' error indicating the expected signals from the hydrostatic transmission are not being received. That would suggest that some of the wiring is still not repaired. Could it be the nice doggie pulled out a connector partially and you didn't notice? Make sure all connectors are firmly seated.
Some have seen this error code occur for the simple reason that the battery voltage was borderline low -- those computers are sensitive. So before you take it to the dealer, put the battery on a charger overnight to see if that resolves it.
Hope this helps. If so, please rate my solutions, thanks and good luck!
Posted on Jun 09, 2010
New Holland tractor
Sensor, wiring or computer failure.
Jun 26, 2016 | Cars & Trucks
Farmall 856 hitch does not raise in zero weather
ck to see what hydraulic oil your using , I bet it's an all weather rated oil, if temp is below zero then that's out of "all weather" range , you will need to look into using a cold weather rated oil (ck with you local dealer to ask ), my tractor has an oil bypass lever you can engage on the valve block this allows oil to circulate around in loop to heat up (+20 degrees) to work in cold temps , I don't think a 856 has one of them
Jan 21, 2016 | Farmall IH Tractor 706, 756, 806, 856,...
John Deere 318. Why won't shifter move from neutral?
the dash is notched were the neutral posisition is , this notch (shift lever needs moved out of notch) is there for two reasons , the one you need to be concerned about is the clutch disconnect , this makes it impossible to shift into any direction without clutch pedal down , sometimes this lever will become bent and not press far enough for release arm of shift lever to allow its movement
love these little tractors , they got all the features of a bigger machine but with the size ease of a compact machine , for a small farm or big home garden there's nothing this machine cant do with the right attachments on it I sure wish JD still made em !
Sep 15, 2015 | John Deere Garden
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
Deere 5525 control stick is difficult to pull back
Are you talking about the three point hitch lever? Does it have a cable going to the three point hitch spool valve? If so, try spraying penitrating oil in the cable at both ends.
Jan 02, 2015 | Garden
How to adjust mahindra 5005 three point hitch down pressure?
1 Draft sensing lever in wrong position
Move lever to "light" position.
2 Rate-of-drop too slow
Adjust rate-of-drop valve.
3 Center link on upper front hole
Move center link to lower hole.
4 Draft control out of adjustment
Refer to service manual for adjustment procedure.
5 Internal mechanical interference with load control linkage
Refer to service manual to find interference, or possibly linkage coming apart.
6 Load control shaft or tube broken or bent
Replace load control shaft or tube. Refer to service manual.
7 Load sensing pin malfunctioning, or bad connections - only applies to newer tractors
Replace load sensing pin, repair faulty connections. Refer to service manual.
Aug 13, 2014 | Garden
I have a 2002 231 s the 3 point hitch will raise or drop on its for no reason
tighten down the friction knob on your up/down lever and set your draft lever to the up position
Aug 20, 2013 | Puzzle Massey Ferguson Tractor
LIFT ARMS FOR 3 POINT HITCH WILL NOT MOVE, NOT SURE WHAT CONTROLS OPERATE
Standard tractors have a lever to the right of the driver, move toward the rear of the tractor to lower ... move toward the front to lift.
May 07, 2010 | Garden
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
400 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
