Question about Stanton C.304
Wont read cd when inserted - Stanton C.304
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Pioneer cd reads disc but wont play?
Look for a different one,It will cost you less then having it repaired,
Nov 04, 2012 | Pioneer Audio Players & Recorders
Mini cd wont load in dvd drive
try cleaning the lens with a q-tip and alcohol
Apr 22, 2012 | Toshiba Computers & Internet
My computer wont read my cd
I suspect that you are using a CD writer and you have possibly inserted a blank DVD into your CD writer. Make sure you have a blank CD inserted instead of a blank DVD.
Let me know if this is your problem.
Best wishes,
Graemevm
Jan 06, 2012 | HP Computers & Internet
Reading disks but wont burn them
The only "help" is to purchase a new "internal" CD-writer, disassemble the casing, remove the "dead" CD-writer, insert the new one, and reassemble the casing.
Nov 05, 2009 | Micro Solutions Backpack Burner
CD-Rom not reading cd's
it sounds like the cd rom driver in windows is not installed correctly try reinstalling the cd rom if that does not work the cd rom needs replaced
Sep 02, 2009 | Dell Dimension 4500S PC Desktop
Wont read or recognise there is acd inserted
When you open my computer do you see the drive in the window? If the drive does not show up in this window you can check two things, check to be sure that the cable connecting the drive to the mother board is good. And the other issue could be that the drive itself has gone bad. If it is unable to read any cd's then you probably need a new drive. Be sure to put in several cd's to be sure it is not the cd disk.
Aug 05, 2009 | Computers & Internet
Cd roms wont read it says i/o device error
Your error is usually indicates that the drive can't read the CD. I ask everyone these two: check to make sure the CD is right-side up (label facing up or to the right on a vertical oriented drive) and did you insert a DVD into a CD drive? Can you use Windows Explorer and right-click on the CD drive letter and select eject and it works? If not, a driver could be missing. Lastly, if you inserted a blank CD (that can be written to) into a CD drive that can only read CD's, you'll get that error.
Dec 26, 2008 | Computers & Internet
AVIC-N1 wont read navigation disc
If your error message is reading "insert appropriate disk" or "inappropriate disk inserted" than I have the solution. Can you just let me know exactly what the message is?
Jun 05, 2008 | Pioneer AVIC-N1 Car DVD Player
My Sony PlaySatation2 console wont read any games on PS2 discs.
Check this web site out, this will help you, this problem happens alot so dont worry you should be able to do it yourself. http://arstechnica.com/articles/paedia/hardware/ps2.ars/1
Mar 12, 2008 | Sony PlayStation 2 (PS2) Console
Stanton C.304 Logo
49 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
