Question about Nakajima AE-740 Typewriter
Not typing - changed correction ribbon, lifted type wheel out, put it back in, checked black ribbon and that is working, but it is still not typing.
  • Nakajima Master
  • 3,594 Answers
Perhaps the correction tape is in wrong, try it wihtout the tape installed.
DickyO
Posted on Sep 03, 2010
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
Hi
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 08, 2010 | Brother EM-530 Typewriter
New ribbon and can't get it to type
did you make sure that the end pieces are engaged into the brackets in the part facing you. Also if the correction tape is not loaded onto the ribbon prior to installing it, it will do that too.
Hope this helps, Denise
Aug 19, 2009 | IBM Office Equipment & Supplies
Lift off tape
Does the tape lift up far enough for correction? If so check to be sure the dull side of the tape is facing the paper. Then be sure you are using a correctable ribbon, the feed wheel should be either yellow or orange. DickyO
Jun 02, 2009 | Brother GX-6750 Typewriter
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Feb 27, 2009 | Brother Office Equipment & Supplies
Ibm Weel Writer 5
Check to see if the ribbon is lifting up, if not there is a black gear on the right side of the printer wiggle it back and forth until it will move. If it is lifting put a multi part form a nd see if it prints on the copies if not the plastic on the print solinoid is probably broken they are available but a bit trigky to install.
DickyO
Dec 10, 2008 | Office Equipment & Supplies
Ribbon is sticking
You may have a wrong ribbon, sometime the small parts where the ribbon turn gear goes into does not match up correctly. Can you turn the ribbon manually by hand, if the ribbon does not turn it will not type....
Apr 17, 2008 | Brother ML-500 Typewriter
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Nakajima AE-740 Typewriter Logo
104 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
