Question about Peavey Pv 2600 Power Amplifier
I have 2 peavey 2600 amps with 1 pv6 mixer wanting to run subs off 1 amp and sp2s off other amp but only have 1 main output on the pv6 mixer whats my solution
    Sergeant:
  • 334 Answers
you can run one amp from the main out puts and the second amp from the CTRL Room out puts. The CTRL ROOM are outputs that are linked to the same bus as the master fader. This will work fine...
Best of luck
Posted on Sep 03, 2010
I only have a vintage Peavey XR600B and I want to connect and ipod and ipad up to it so I can play music. Can I do this or do I need special cables?
Sure you can, but that mixer amp is a mono amp instead of stereo. Head for radio shack and get an 1/8" stereo male phone jack to 1/4" female mono adaptor. Plug the adaper into the headphone output of your device. Then run a shielded cable with 1/4" mono phone plugs on both ends (like an electric guitar would use) from the device to one of the channels on the Peavey. Bring the volume up on both the channel and master on the amp up maybe 1/3 the way. Play a track on your device and adjust the devices out put as high as it will go with out distorting the channel input. Then adjust the amp's channel and main output as you would normally to get the final volume you need.
Jun 28, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
How ti install in chain to amp input
the instrument should be plugged into the LINE jack, and the amp should get it's signal from either the MAIN L or R jacks
Feb 17, 2014 | Peavey PV6 Mixer
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
How to connect subs and mains to the same pv2600
This will depend on your Subs. If they have an inbuilt crossover there will be input and outputs on the rear, with the output marked something like 'tops' or 'Output to HF'
If you have these then it should be a simple matter of connecting yout amp to the subs and then the mains to the output.
If you haven't got a crossover in the subs then you will either need to buy a pair of two way crossovers for the right power and frequency and have these in the speaker wiring or use the amp's inbuilt crossover and run one channel for tops and the other for subs. You will lose stereo but the amp will happily drive a 2ohm load so you should still be able to use all four speakers.
Feb 06, 2014 | Peavey Pv 2600 Power Amplifier
I have connected a laptop to a Phonic MM 1002a mixer, Do you need to use both Channel A & B on Peavey M - 2600 Mark V Stereo Am
This depends on what you are trying to do. If you want a mono output from the amp switch it to mono mode and go into one input on the amp, this will mean the amp only works mono.
If your source is stereo you will need to use two inputs on the mixer and pan them both to the side you will be sending to the amp. This will cost you two mono inputs on the mixer though.
If you have anything stereo this is the route you will need to take but I don't see why you would want to do this as surely you'd be better running everything stereo (two channel) and panning any mono signals where you want them and leaving stereo as stereo.
Jan 02, 2014 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
How do i connect this amp to my powered mixer ( behringer europower 500)
Using TRS (balanced audio interconnect cables) go from the main output on the top of the panel to your amp inputs. MAKE SURE the amp is powered from the same receptacle as the mixer to avoid ground bounce and possiblle damage to your units.
Jul 14, 2011 | Peavey Pv 2600 Power Amplifier
I feel like a dork asking this question but how do you connect the amplifier to your mixer. I see that there are places for a banna plug however my mixer will not take a 1/4 banna plug.
In case you don't have one, here is a link to the manual:http://www.peavey.com/assets/literature/manuals/80300573.pdf I don't know if you are using a separate crossover between the mixer and the amp but here is the simplest explanation.I just reread your question and I don't even know whether you have a Peavey amp. Run proper cables from the main output of your mixer to the main inputs of your power amp.They will be 1/4"shielded cables or Balanced XLR cables. Do not use unshielded speaker cables to hook the mixer and the amp together.Run speaker cables from the speaker outputs of the amp to the input jacks of your speakers.Make sure the impedance of your speaker cabinets equals or exceeds the impedance rating marked on your amp. Here is the link to the newer model PV2600 manual:http://www.sweetwater.com/store/media/pv2600_doc_manual.pdf Don't use Speakon cables unless your speaker cabinets are equipped with Speakon input jacks. Banana plugs aren't as solid a connection as the binding posts are.
Nov 07, 2010 | Peavey Pv 2600 Power Amplifier
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Intermittant LR output problems Main outputs (XLR
Intermittent problems cn be a real pain to find... BUT I want you to verify your use of the mixer and its connections as one can cause the output drivers to latch up due to ground bounce.
Make sure your outputs go to the power amps AND into balanced inout at the amps... either XLR or TRS connectors.
Make sure that the amps are POWERED from the same receptacle as the mixer... even if you have to run power back to the mixer. If you power the mixer from a different receptacle at the other end of the room, ground bounce of the safety ground MAY exceed the common mode drive of the mixer and cause the output drivers to latch up or even be destroyed!!!
Aug 11, 2010 | Peavey 32fx USB 32 Channel Mixer
What is the best suited power amp for the Peavey PV14 mixer board?
that depends on your speakers, not the mixer. the amp should be matched to the speakers, in watts and in ohmage. for example, 400 watt, 8 ohm speakers should get an amp that runs at 350-500 watts at 8 ohms.
Apr 22, 2010 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
111 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
