Question about Directed 434MHZ Remote Control
Zenith pip-system 3 code for remote
I need the code to my zenith pip-system 3 tv to enter into a universal remote
  • Anonymous Apr 26, 2009
    can't find a code for a zenith system 3 tv
minteker
  • 52 Answers
SOURCE: universal remote code????
Hey...here's a bunch of codes that i found for alba tv's:
ALBA 003 009 011 027 028 053 062 068 083 162 169 171
Try em out, good luck!
Posted on Mar 12, 2008
  • 1694 Answers
SOURCE: Emerson TV- Sentry Really Big Universal Remote
www.remotecodelist.com .........................................T.
Posted on Mar 22, 2008
XRAYRON
  • 156 Answers
SOURCE: code for apex tv through philips universal remote
Try these APEX TV codes 0023 0223 0123 0741 Thats from the CL034 Code book
Posted on May 02, 2008
aprmaejun
  • 97 Answers
SOURCE: philips pm 335 universal control
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
Posted on Jun 21, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
Need 3-digit code for sanyo fxwe universal remote for a 19 in. zenith tv.
If you have a universal remote, you should be able to perform a code search to find what you want
Nov 02, 2012 | Televison & Video
My universal remote needs a code to be programed to my tv. my tv brand is zenith
There are many codes for Zenith TV's. First, try this website:
http://www.jascoproducts.com/support/universal-remote-codes.asp
Note if your remote uses 3-digit codes or 4-digit codes, and choose the appropriate code list.
May 02, 2010 | Universal Remote Control GE174Universal...
I need the code for a rca remote (rcr311w) for a zenith TV
I am very happy to help you reprogram your RCA RCR311W for your Zenith TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up on this remotes device code list.
I hope that helps.
Mar 07, 2010 | RCA 3-dev Universal Remote Remote Control
Need code to program a universal remote!
general process for a universal remote control:
  1. push and hold setup 3 seconds
  2. select the device to control (TV DVD etc)
At this moment TV has to be ON (turn tv on by front panel)
3. continue with remote control pushing power button again and again and again SLOWLY
4. when the tv turns off then press enter to save your code.
Apr 14, 2009 | Televison & Video
Need code for ge jasrm24912 universal remote control zenith tv
I have a brand D tv and i am trying to get a code to program the remote control GE JASR24912 3- Device to my tv .
Jan 16, 2009 | GE RM24912 Universal Remote Control
Need all codes for the universal remote zenith zn bb5
I used the code provided by Philips Universal remote. It works great. One thing you have to ignore the first digit. Just use the last 3 digits only.
Mar 02, 2008 | Zenith ZN-BB5 Remote Control
Need code for zenith Televison
I don't know if you need the 3 or 4 digit code for your specific remote. I have found the site that provides the codes for your universal control.
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Zenith HDTV
If you have a 4-digit remote, it should be 0634
If you have a 3-digit remote, it should be 634
Zenith standard TV (there's a bunch)
3-digit: 000, 001, 004, 009, 023, 038, 039, 050, 058, 059, 064, 078, 091, 111, 121, 131, 134, 135, 136, 153, 226, 227, 245, 247, 252, 266, 288, 310, 338, 358
4-digit: 0121, 0009, 0050, 0078, 0091, 0138, 0059, 0131, 0038, 0111, 0134, 0153, 0064, 0004, 0135, 0226, 0227, 0245, 0247, 0252, 0266, 0288, 0310, 0338, 0358, 0023, 0058, 0039, 0001.
I hope this helps!
T-Mo
Feb 09, 2008 | GE RM24911 Remote Control
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Televison & Video Logo
476 people viewed this question
Top Directed Televison & Video Experts
ted dux
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
