Question about LaCie 1TB D2 HD Quadra FireWire 400 Hard Drive
The hard drive is working fine but as I added it as a second Lacie drive (daisy chained) some of my files in my main drive were switched around. Using Pro Tools, the sound banks stored in my 2nd drive are not accessable to the plug-ins. It's strange because they are visually there but a pop-up states "Sounds Not Found". It may not be related but it happend when I booted up after the 3rd drive was added. What to do? Allan
  • 1,606 Answers
My wife just bought one of these a few weeks ago. We noticed right away that it would loose or change settings. If it powered down you had to reboot it or the computer or both before it would recover. There was also some issues with security settings. The driveitself seems to be fine but windows or the ports settings do need to be played with to get it to behave. I changed the time outs and power tomax out and it seemed to settle it down on ours. Not sure this will help in your case but it seems to be where these problems come from.
Posted on Sep 02, 2010
When my computer is in sleep the blue light on my lacie turns off, and then it will flicker and then goes off again and it will continue doing this
Probably due to sleep mode. The computer will power off things such as USB ports. You can disable "Allow the computer to turn off this device to save power" under Power Management tab in Device Manager on each "USB Root Hub". Not sure if there is an equivalent on Mac
Feb 01, 2013 | LaCie Computers & Internet
Lacie ED mini v2 won't start up.
I had the same problem twice, but it was the power adapters each time that were causing the problem. It wasn't the unit itself. Lacie replaced the power adapters and it worked fine.
Nov 08, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
Firewire problem I think - I have a Sony Vaio laptop, the firewire port is 4 pin, it is connected to a LaCie CD Burner via 6 pin and the burner is daisy chained to a AcomData external hard drive via 6 pin....
If the hub has an external power supply it migh do the trick. That way you can have a backup port if needed.
Make sure the hard drive isn't connected to the hub. Sometime windows doesn't see it when its connected to a hub.
Jul 14, 2008 | Computers & Internet
File transfer size limitation for LACIE HD
hi
can i suggest that you use winrar to divide the file size of your file that you want to transfer to your lacie. this might work.
download winrar @ majorgeeks.com
but if you LACIE still says that it does not have any disk space left...i would suggest that you reformat the HD instead. but make that a last resort...
hope this helps
Jan 21, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie Mobile 500gb not working
Just buy new external ( HDD ini is fine) just change the external for both off you
Dec 28, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Daisy chain my external hard-drives
I don't think these drives are designed to be daisy chained. This worked for SCSI drives, but not for USB drives.
Dec 20, 2007 | LaCie d2 Extreme 250GB External with...
URGENT HELP NEEDED (editing a film) G4 0S 10.4
It sounds as if the enclosure has failed. IF THE DRIVE IS GETTING POWER, but not making strange noises, you may just need to extract the drive from the enclosure. Keep your fingers crossed. If the drive has been affected, data recovery may be the solution. Good luck.
Sep 06, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
LaCie 1TB D2 HD Quadra FireWire 400 Hard Drive Logo
51 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
