1 forth of the screan is darker color - Televison & Video
  • ELMO04 May 10, 2008
    1/4 of the picture is green 3/4 is black
  • ELMO04 May 12, 2008
    This is a portable dvd player. when I put in a different dvd the same thing happens but the picture and aduio is fine just have the 1/4 of the color is lighter.
  • 3,037 Answers
Alright, so if you answer a few questions for me I would be happy to help you out.
If you are on cable, antenna, dish, etc. does this still happen?
If you try the dvd player on a different tv, does that tv experience the same problem?
If you try a different DVD does this one still have the same problem?
If you try a different cable from the player to the tv, does it still have this problem?
Besides the color, is the picture still good and the audio?
Please get back to me on all of these questions so we can narrow down the exact problem, thanks.
Posted on May 12, 2008
  • Benjamin Patri
    Benjamin Patri May 12, 2008
    ok, now it makes sense. What is probably happening is that there is a looser connection for the power going to that corner. It is an internal hardware problem and requires you to physically open it and check the board and wires and make sure they are firmly connected. It may also have been caused by pressure to that corner.
  • Benjamin Patri
    Benjamin Patri May 23, 2008
    Were you able to fix this or do you require further assistance? Please let me know as I would be happy to do what I can.
    Have a good day
    President:
  • 2,712 Answers
This seems to be a problem more with the TV than the DVD player. One way to determine this, is to try it on a different TV and using a different disc. If the problem still occurs, then it could indicate a problem with either the DVD or the connecting cable. Use a different cable to find out if the problem is with the cable. If not, then you will have to get the DVD player serviced.
If the problem does not occur in the other TV, then the fault could lie with the original TV. In this case, you will have to call in a repairman to get your TV fixed.
Hope that helps!
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 12, 2008
    Ok, so this is a portable player. Please try to give as much information as possible when you describe the issue. Now that we know it a portable player, it changes the scenario..
    There seems to be a problem with the internal circuitry or the connector from the logic board to the screen. It could also be a case of a loose connector or poor soldering inside. There is no other option but to get it serviced, as I wouldn't recommend opening up the player if you have no prior experience in this sort of thing..
  • Swilin Sampson
    Swilin Sampson May 18, 2008
    Just checking to see if your issue is resolved. If it is, please assign
    a Fixya rating for the Expert whose advice guided you to a fix.
    Cheers!
  • Swilin Sampson
    Swilin Sampson May 23, 2008
    Hello, just wanted to know if your issue has been resolved. If you have any further questions, please post back and let me know.
    Sergeant:
    Champion:
  • 230 Answers
Regarding replacing backlights, some newer LCD panels have an integrated backlight- you can't replace just the light, you must replace the entire screen. I would assume this applies more to laptops as I repaired a Sony Vaio that lost its light. You could make out the Windows boot screen (if tilted at angle). On opening, I discovered this. And I found an inexpensive source for the panel: http://www.screentekltd.com
  • balachander megavarnam
    balachander megavarnam May 13, 2008
    try to reset the factory settings by using the owners manual................
  • 13,433 Answers
Try another source, if the same problem appears there then your tv is in need of repairs, contact a local service center or tech.
    Genius:
  • 3,422 Answers
Can you please give more details on your problem so that i can help you fix it.
Posted on May 10, 2008
  • Priya darshan May 10, 2008
    Ok so your having a problem with Tv colour?But why did you post it under the DVD category?
    Anyways try a hard reset by unpluging all the cords for 30min and then plug it back in.
    I'll let you know if there is a manual available for this model.
HOW TO INCREASE BLACK TO A DARKER COLOR ON A EPSON XP830
Normally you can change the color darker or lighter by adjusting the density. Most likely you have a panel on the printer where you can change it.
Sep 03, 2017 | Epson Office Equipment & Supplies
Hello, I got the silent shaft, timed with the cam, crank and oil pump, thank you for the help with comments. now that it is runnin, it runs rougher then before i replaced the water pump and timing belts...
The only way to tell if you have a ring or valve problem is to do the compression test as it the best place to start . Once you have eliminated the compression from the equation then you can concentrate on why the cylinder is getting more fuel than the others. I would be checking for vacuum leaks for the rough running as an incorrect fuel / air ratio will cause missing. We cannot fix everything but we endeavour to point you in the right direction so that you can fix it.
Oct 06, 2013 | Dodge Ram 50 Cars & Trucks
My screen has gotten much darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 24, 2008 | Hitachi 53SWX12B 53" Rear Projection...
Darker color printing
dear Friend pls check your print Quality in printer preference setting ,is it possible due to Hi density (print Resoluction)
other wise Check printer on other New computer with new Printer Drivers Installation
May 29, 2008 | HP LaserJet 2420dn Printer
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Mar 18, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Pixel color fade
You are about reade to have a scan ic failure.Try to get it to a repair center asap.Have them replace the top 2 scan ic's
Jan 28, 2007 | Pioneer PureVision PDP-5030HD 50 in....
Televison & Video Logo
Top Televison & Video Experts
