Question about Speed Queen AGS28AWF Gas Dryer
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
    President:
  • 3,074 Answers
Burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Posted on Sep 02, 2010
My speed queen model AGM499W does not dry clothes cycles off and on after 10mins
Here is what I did. I went to the breaker box and reset the breaker for the dryer. Sometimes it will only pop 1/2 of the breaker, due to being too hot.
Hope this works
Nov 09, 2012 | Dryers
I DONT HAVE A GAS DRYER AND I JUST BOUGHT A HEATER ELEMENT JUST DON'T KNOW WHERE TO PUT IT ON MY SPEED QUEEN DRYER
If does vary by model of SpeedQueen dryer,but typically the heat element fit in the bottom or the rear plate the supports the drum..reply with model number and i will tell you where yours goes.
GENE
Sep 04, 2011 | Speed Queen AES68AWF Gas Dryers
My speed queen dryer model #AES68AWF doesnt heat what could it be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
I have a speedqueen gas dryer model AGM499w iGNITER LIGHTS BUT NO FLAME
heatman101';
May 24, 2011 | Speed Queen AGS28AWF Gas Dryer
I have a speed queen gas dryer model number Aqm499w2 that will not heat up.
Better give technicians a call your problem seems the igniter is busted.
Nov 06, 2010 | Speed Queen AES68AWF Gas Dryers
My speed queen gas dryer comes on but will no longer heat. The igniter is fine.....passes the Ohm test. What might be the solution? And what are the est. part costs....this is an old speed...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It works on amps... not ohms...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Dryers
Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
I have a Speed Queen gas dryer AGM499W. It won't dry. The gas ignighter comes on but gas does not light.
There is a light sensor near the igniter. Clean off the dust on it's glass face. Don't bump the igniter, it's delicate.
Apr 22, 2009 | Dryers
Speed queen commerical dryer
try replacing the gas valve coils. they are cheap
Jul 25, 2008 | Speed Queen CGS68AWF Gas Dryer
Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
Jul 23, 2008 | Dryers
Speed Queen AGS28AWF Gas Dryer Logo
331 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
