Question about Royal Office Equipment & Supplies
I have a ht500x it shreds,but it is making a grr noise
  • 1,606 Answers
You may have something stuck in there or someone ran something that was too thick through and the drive gears were damaged. If it is something stuck the sound will be higher pitched (usually) and may stop when you run smethign else through. If it is the gears they ma not last and probably getlouder when you put stuff through. If you put your hand on the side when running paper through you can probably feel the vibrations of the gear. All it takes is a stable or a few too many sheets of paper and so on and the gears can be damaged. Not much you can do except replace it if thats the case. If it is under warrenty you can try but they usually will say user abuse and do nothing.
Posted on Sep 02, 2010
My 99 Plymouth breeze has to get a jump just to start Everytime wat is the problem and how do I fix it
Weak battery is my guess. You haven't mentioned any cran (GRR GRR), clicking noises, lack of dashboard lighting, or absence of sounds of a fuel pump noise (before the starter kicks in.)
Jun 12, 2017 | Plymouth Cars & Trucks
Shredder is making a loud noise when attempting to shred a document.
The shredding mechanism could be clogged to the max or someone tried to shred a credit card or plastic coated material.
Feb 06, 2017 | Shredder Office Equipment & Supplies
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
When I put paper to shred ,all I get is motor noise but no shred
You probably have a stripped drive gear. let me know what brand shredder you have.
May 14, 2010 | Office Equipment & Supplies
My shredder HT500x is making a grinding noise & not taking paper
Empty the can,run it in reverse for a minute,then forward,also try lubricating the cutter with silicone spray.
Apr 07, 2010 | Royal HT3SL Shredder
Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the paper...do this a number of times this will get the oil down into the cutting shafts.
May 01, 2009 | Royal VF1000MX Shredder
Won't shred
maby the blades are blunt thats what it sounds like to me i had this problem with my shredder
Jul 18, 2008 | Adler Royal HT500X Shredder
Makes noise but won't shred
Had the same prob with a Schneider shredder. The roll pin that secures the nylon driven wheel to the blades shaft was sheared. Easy fix in a way but original pin was a metric size.
Jul 13, 2008 | Tech Solution TS-2550 Shredder
Ford mondeo td
Your Power steering pump may be loose. This may be reason for the belt shredding and will make the new belt shred too pretty soon.
Nov 24, 2007 | Car Audio & Video
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
