Making duplicate copies of the scanned form.
Can I use my scanner as a copinging machine to obtain duplicate copies? If so please send me instructions. Thank you
  • tellkid May 11, 2008
    The window I get when I scan the document does not indicate a "print" function and I am unable to locate another screen which does allow printing.
  • Rob Wilkins May 11, 2010
    What exactly is it that you are trying to do? Once you have scanned a document, you should be able to simply print it out as many times as you wish to get as many copies as you need.
All ok. The problem has now been resolved. One contact was not connected. Thank you
Posted on May 11, 2008
Can you please send me the user / instruction manual?
Bread Machine Digest ยป Generic Bread Machine Instructions
www.breadmachinedigest.com/.../generic-bread-machine-instructions.ph...
If you are looking for the manual to your bread machine please visit our Archive ofBread Machine Manuals. ... You may need to use a rubber type washer when youinsert ..... Does anyone have the owner's manual they could send to me?
24892290 Can you to send me a manual for a bread making?
bacbec.no-ip.net/F/support/t24892290-send_me_manual_bread_making
... citizen bread maker recipe book can you please send me a scanned copy of the ...this bread machine without a manual this user s manual now you can enjoy ...
2400462 LOST MANUAL AND RECIPES BOOKLET CAN ...
bacbec.no-ip.net/F/.../t2400462-lost_manual_recipes_booklet_e_mail_m...
Solution: lost recipe book that came w my premier donvier ice cream maker need ...anne please use the private message feature citizen bread maker recipe book ... thatmanual can you please send me a scanned copy of the bread manual for ...
Feb 03, 2016 | Kitchen Appliances - Others
How to fix double vision print?
Hello
The duplicate print is a problem you can fix easy, only need...
1. calcium grease
2. and put in the iron making
with the next steps...
Solving problem of duplicate letters in Canon printers
http://www.en.rellenadodecartuchos.com/2015/11/solving-problem-of-duplicate-letters-in-canon-printers.html
Nov 19, 2015 | Canon PIXMA MG3550 Inkjet Multifunction...
I have an HP laserjet m2727 mfp series 4 in 1 multipurpose that can only print and recieve fax. What would be the problem? Please help me.
The detail isnt clear.
But if your machine doesnt do copies, scan or send faxes it would seem that ther is a problem with the scanner unit on your machine, Lift the ADF unit (as if you wer to do a copy from the glass) keep the lid open so you can see the scan unit, do a copy and check if the scanner unit moves and check if the bulb is burning.
These machines are notorius for dodgy formatter boards.
But i would start with checking the scanner unit.
Feb 18, 2011 | HP Laserjet M2727nf Multifunction Printer
When I send a fax the receivers copy is black.
Make a copy with the machine. If it comes out black as well your scanner has gone bad. In other words when you insert an original to be "scanned" so it can be faxed or copied, it is being read as all black. Usually this occurs because the row of led's that light up the original go bad. Now I have seen in some cases, if you unplug the machine for a bit then power back up the problem goes away so try that. Test by making a copy. If this does not work then your are looking at a scanner assembly replacement or just get a new machine.
Good Luck and Thank You for using Fixya.
Aug 25, 2010 | Brother IntelliFAX 4100 Laser Fax
Black copies being received
Your image scanner is bad. Try making a copy....if it comes out black but your incoming faxes are fine then your image scanner is bad. You can also print a report from the machine and it should come out fine.
The image scanner is the part that scans your originals before faxing them out or making a copy. There is a light bar that lights up when scanning. Either that light bar(l.e.d. array) has gone bad or the scanner itself is bad. If this is the case it is probably going to cost more to fix than the machine is worth. You could buy a new machine for what it would cost to fix.
Apr 22, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Black pages received when faxing to others
Your scanner array is bad. This is a light "bar" that lights up to scan your originals before they are sent out. You can test for this by making a copy with your machine. The same scanning function is used to make a copy as it is when you scan to send a fax. If you make a copy and it comes out black then your scanner is bad. This is especially true as when you say that the problem goes away for a short time after turning the machine off. This allows the circuit to cool and the solder connections to shrink and make contact. As the board heats up the metal contacts expand and "open up", causing the scanner to fail.
Not a cheap fix unfortunately.
Mar 16, 2010 | HP LaserJet 3050 All-In-One Printer
When you send a fax, the other person only gets lines on there copy, not the paper that i faxed
Make a copy with your fax machine. If your scanner is bad you should have a similar problem making copies. The same scanner is used to make a copy as is used to scan and send a fax. If the copy comes out bad your scanner is either dirty or bad. If you can see your copy but it just has a few lines running vertically up and down the page then you need to clean the scanner glass. This is a small strip of glass in the port where you feed it your originals.
Good Luck
Jan 25, 2010 | Panasonic KX-FP151 Plain Paper Thermal...
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
k24674
jasbo
jasbo
