Question about Toshiba 32A3000 32A3000 32 16:9 Multi System Regza 1366 x 768 HD LCD TV
If i turned ON , sometimes , tv screen and image does not appear but sound is on ! That problem appear not all the time i used TV and if i turned off and on a few times - that inconvenience is dissapear and image & tv screen is displayed as normal ! What is it ? My tv is a Toshiba Regza 32 A 3000 model !
    Genius:
  • 1,622 Answers
Check for dry soldering, bulged capacitor, but if otherwise Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Thanks and take care...
Posted on Sep 02, 2010
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Black TV screen: no image, just sound
Sounds like the brightness might have been turned down. Does it have a manual brightness control? Sometimes there is a combination of buttons you can push on the remote to reset the TV to factory specs. Add some more info about the TV, Make, Model #
Feb 17, 2014 | Televison & Video
I have bought a new philips colour tv just 3 months ago.after watching tv for sometime whenever i power off the tv i can see some colour spot red,green....on the centre of the screen.even after removing...
This problem is known as image retention and is a problem with the PDP. Turn on the set when you see these spots and see if they appear on the image too. If they persist, then its time to use your warranty to get a replacement.
Dec 31, 2010 | Televison & Video
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
LCD screen gone dark, can still hear sound and see image
It wouls appear one of the backlights in the screen is cutting out, this will require the screen to be replaced although in certain circumstances, depending on the age & model of your TV, it is sometimes possible to change the faulty backlight independantly. Take it to a repair centre to get an anaylisis of the type of screen it has.
Aug 22, 2009 | Televison & Video
Problem with 32-inch Toshiba flat screen tv
yes take it back sounds like a back light issue
shad
Jan 04, 2009 | Sharp R-1480 Microwave Oven
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Toshiba 32A3000 32A3000 32 16:9 Multi System Regza 1366 x 768 HD LCD TV Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
