Question about Car APS57A Remote Start and Keyless Entry System with Trunk Releas
I AM WORKING ON MY FRIENDS STREET ROD THAT HAS A ROSTRA MODEL APSR-4 CHANNEL WIRELESS RECEIVER THAT CONTROLS THE DOOR RELEASES AND THE COURTESY LIGHTS. i DON'T HAVE THE KEY FOB/ REMOTE ENTRY MECHANISM AND A CONVERSATION WITH ROSTRA DIDN'T PRODUCE FRUIT OTHER THAN THE FACT THAT THIS UNIT IS OBSOLETE AND THEY DON'T MAKE AN UPDATED MODEL. THEY REFERED ME TO AUDIOVOX. HERE I AM.....THE UNIT IS A 4 CHANNEL/12VDC. DO YOU HAVE ANYTHING THAT WOULD BE COMPATABLE WITH THIS ?? DON BRETER
2 Suggested Answers
logosc75
  • 625 Answers
SOURCE: I bought a new key
Did the unit have anything plugged into the blue two pin port? If so, trace that wire (black & gray) to the programming switch. Once you have located the switch, turn key on, press and release the button three times. The parking lights will flash once. Press the lock button on the new remote. Press and release the programming button once (two flashes), press unlock button. Press and release probramming button once( three flashes), press remote start button. Press and release programming button once (four flashes), press option button. Turn key off. test system.
Posted on Nov 30, 2010
2008 Saturn Vue Hybrid courtesy lights up front and mid cabin don't go on when door is open. Rear cargo does. Otherwise they do work
When the body control module (BCM) is in an active state (awake) it energizes the courtesy lamps supply voltage circuit. The courtesy lamps supply voltage circuit supplies voltage to all of the interior lamps, including the illuminated entry lamps (courtesy lamps). The illuminated entry lamps are turned ON when they receive a battery positive voltage from the courtesy lamp supply voltage circuit of the BCM. When the ignition is in the LOCK position the BCM will apply the courtesy lamp supply voltage circuit under the following conditions:
• The door jamb input transitions to an active state (opening a door).
• The use of the remote keyless entry (RKE) to unlock the side doors.
Do you know how to do automotive electrical circuit testing using a DVOM- digital volt ohm meter and a wiring diagram to pin point testing areas of a circuit ?
Circuit/System Description
The body control module (BCM) applies battery voltage to the courtesy lamps through 2 separately controlled courtesy lamp supply voltage circuits. When any door is opened, the door ajar switch contacts close and the BCM receives a door-ajar input. If the BCM receives a door lock or unlock input or a rear hatch open input, the BCM will activate the courtesy lamp supply voltage circuits, providing battery voltage to all of the instrument panel (I/P) courtesy lamps, dome lamps, rearview mirror lamps, and rear compartment lamps. In the event that any of these lamps were to remain illuminated for more than 20 minutes with the ignition switch in the OFF position, the BCM will deactivate the courtesy lamp control circuits to prevent a total battery discharge condition.
You can view free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine ! Under system click on lighting ,then under subsystem click on interior lighting . Click the search button then the blue link. Looking at the first diagram you will see on the top left a fuse box , this B+ for the BCM ,top right is the BCM .You will see three wires coming out the bottom of the BCM , these go to your courtesy lamps , The thing's that look like a open switch inside the BCM , they are transistors or high side drivers . When commanded these supply B+ voltage to the lights . Finding the BCM an testing output voltage would be my first step , before taking the inside of the vehicle apart to find wiring harness to test .
Jul 01, 2017 | Saturn Cars & Trucks
My interior light won't come on in my 1999 Buick Lesabre. I have checked the bulb & the fuse. Can anyone help me with this problem? Any ideas are sincerely appreciated.
Courtesy Lights
The courtesy lights come on under the following conditions:
Any door is opened.
The interior lamp switch is in the ON position.
The keyless entry transmitter unlocks the doors (illuminated entry).
When the key is removed from the ignition switch with all of the doors closed, the courtesy lights light for approximately 25 seconds before fading out.
Battery positive voltage (B+) is applied at all times through the IP fuse block CTSY LP/PWR MIR fuse 6A via CKT 640 (ORN) through the body control module (MALL) to the courtesy lights via CKT 1732 (ORN). The MALL provides a ground through CKT 156 (WHT) for the courtesy lights under the following conditions:
The MALL receives an input from a door being opened.
The MALL receives an input from the interior lamp being turned ON.
The MALL receives an input from the doors being unlocked using the keyless entry transmitter.
The courtesy lamps then light.
When the courtesy lights are activated by opening and closing a door, the courtesy lights will remain on for approximately 25 seconds before fading out after all of the doors are closed. If the ignition switch is turned to START or RUN within the 25 seconds, the lights immediately begin to fade out. If a door is left open, the MALL removes battery positive voltage (B+) to the courtesy lights after 10 minutes. When the courtesy lights are activated by the interior lamp switch, the lights remain on as long as the interior lamp switch is in the ON position. When the courtesy lights are activated by unlocking the doors using the keyless entry transmitter, the lights remain on for approximately 40 seconds. If the doors are locked using the keyless entry transmitter within the 40 seconds, the lights immediately begin to fade out.
Body Control Module (MALL) Diagnostic Mode
For a detailed explanation of the MALL module diagnostic mode, refer to Body Control Module Cell 51.
What interior light ? Dome , courtesy lights etc....They don't work with switch, keyless entry , door opening ?
What
Dec 03, 2015 | Buick Cars & Trucks
I have a 2004 Silverado and when I open the passage door none of the inside lights come on but the drivers side does please help
The left and right front door courtesy lamps are controlled, and receive voltage and ground from the drivers door module (DDM) and the passenger door module (PDM) respectively. The body control module (BCM), DDM, and the PDM communicate through class II serial data for the lamp illumination commands and the door ajar switches.
The remaining courtesy lamps are controlled and receive voltage from the BCM. Voltage for the courtesy lamp supply voltage circuit and the backup lamp supply voltage circuit is from the TBC B fuse in the instrument panel fuse block directly through the BCM to these circuits. A short to ground on either of these circuits will open the fuse. Ground is provided to the footwell lamps and all courtesy/reading lamps at G203. Ground is provided to the right middle and right rear door at G306. Ground is provided to the left middle and left rear door at G302.
There could be a DTC - diagnostic trouble code stored in the BCM
DTC B2615
The body control module (BCM) receives a ground signal from the door jamb, liftglass/liftgate if equipped, or courtesy lamp switches requesting courtesy/dome lamp illumination. When this occurs, the BCM directly sends a voltage through the courtesy lamp supply voltage circuit illuminating the courtesy/dome lamps.
Voltage for the courtesy lamp supply voltage circuit as well as the backup lamp supply voltage circuit is from the left instrument panel fuse block TBC 2B 15-amp fuse directly through the BCM to these circuits
DTC B3801
The body control module (BCM) monitors the courtesy lamp switch signal circuit in order to determine when the courtesy/dome lamps should be illuminated. When the BCM senses that the courtesy lamp switch signal circuit is grounded when the switch is activated, the BCM will illuminate the courtesy/dome lamps.
Inspect the following related body control module (BCM), driver door module (DDM), and passenger door module (PDM) data parameters. Refer to Scan Tool Data List or Scan Tool Data Definitions for typical values and definitions:
The courtesy lamp switch
The interior lamp defeat switch
The door ajar switches
Was a problem found?
Go to Step 7
Go to Step 10
Oct 20, 2015 | Cars & Trucks
Interior lights not working
You mite have a DTC - diagnostic trouble code stored in the BCM - body control module , The BCM controls the interior lights ! Have you heard of a BCM ?
DTC B2615
The body control module (BCM) receives a ground signal from the door jamb, liftglass/liftgate, or courtesy lamp switches requesting courtesy/dome lamp illumination. When this occurs, the BCM directly sends a voltage through the courtesy lamp supply voltage circuit illuminating the courtesy/dome lamps.
Conditions for Setting the DTC
When the BCM receives a courtesy lamp illumination request signal and the courtesy lamp supply voltage circuit is shorted to ground.
When the BCM is not receiving a courtesy lamp illumination request signal and the courtesy lamp supply voltage circuit is shorted to voltage or open only to the first splice from the BCM.
There is a loss of the rear fuse block TBC 3 battery supply voltage to the BCM for more than 1 second
Diagnostic Aids
Perform a visual inspection for loose or poor connections at all related components. Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
Only an open circuit up to the first splice from the BCM will set DTC B2615.
DTC B3801
The body control module (BCM) monitors the courtesy lamp switch signal circuit in order to determine when the courtesy/dome lamps should be illuminated. When the BCM senses that the courtesy lamp switch signal circuit is grounded when the switch is activated, the BCM will directly illuminate the courtesy/dome lamps. Do you know what a scan tool is ? not a code reader !
Courtesy Lamps Inoperative
GM Tech 2 Training video 1996
Aug 24, 2015 | 2004 Chevrolet Chevrolet TrailBlazer EXT
2009 dts inside lights stay on
this could be a door switch problem or a BCM problem. access the BCM for codes and data this will help. check to make sure the headlight switch for the interior lights is in the off position.
Mar 20, 2015 | 2009 Cadillac DTS
2004 yukon slt courtesy light relay location
Here is a description of the courtesy lights , there is no relay ! Controlled by the BCM - body control module !
The courtesy/illuminated entry lamps, may be manually turned on or off by placing the interior lamp switch in the ON or OFF position. If an outside door handle is lifted or a door is opened, the courtesy/illuminated entry lamps illuminate. After all the doors have been closed the courtesy/illuminated entry lamps will remain illuminated approximately 15 seconds. The courtesy/illuminated entry lamps will also turn on prior to any door being opened, and remain illuminated approximately 40 seconds when the driver removes the ignition key. When the driver places the dome lamp defeat switch in the OFF position, the courtesy/illuminated entry lamps will be disabled.
The left and right front door courtesy lamps are controlled, and receive voltage and ground from the drivers door module (DDM) and the passenger door module (PDM) respectively. The body control module (BCM), DDM, and the PDM communicate through class 2 serial data for the lamp illumination commands and the door ajar switches.
Mar 17, 2015 | Cars & Trucks
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
Keyless entry not working
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Remove key. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press each remote control lock or unlock button twice. Ensure doors lock and unlock after each remote control operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
NOTE: A maximum of 3 remote controls can be programmed.
Mar 29, 2010 | 2004 Mazda 6
Programing garagedoor opener
HOMELINKT UNIVERSAL
TRANSMITTER (IF EQUIPPED)
The HomeLinkt Universal
Transmitter, located underneath
the driver’s visor, provides a
convenient way to replace up to
three hand-held transmitters with
a single built-in device. This
feature will learn the radio
frequency codes of most current
transmitters to operate garage
doors and gates, and can also
control home or office lighting and
security systems (with the
available accessory package).
NEXT
MODE
Controls and features
42
When programming your
HomeLinkt Universal
Transmitter, you will be
operating the garage door or
gate. Be sure that people and
objects are out to the way to
prevent potential harm or
damage.
Do not use the HomeLinkt
Universal Transmitter with any
garage door opener that lacks
safety stop and reverse features as
required by U.S. federal safety
standards (this includes any garage
door opener model manufactured
before April 1, 1982). A garage
door which cannot detect an
object, signaling the door to stop
and reverse, does not meet current
U.S. federal safety standards. For
more information on this matter,
call toll-free: 1–800–355–3515.
Programming
1. Prepare for programming the
HomeLinkt Universal Transmitter
by erasing all three of the factory
default channels by holding down
the two outside controls until the
red light begins to flash (20-30
seconds). Release both controls.
2. Hold the end of your hand-held
transmitter against the HomeLinkt
Universal Transmitter (located on
your visor) while keeping the red
light in view.
43
3. Using both hands, press the
hand-held transmitter control and
the desired channel control on the
HomeLinkt Universal Transmitter.
Do not release the controls until
step 4 has been completed.
4. Hold down both controls until
the red light begins to flash slowly
and then rapidly. Rapid flashing
indicates successful programming
of the new frequency signal.
5. Follow steps 2 through 4 to
program the remaining two
channels.
If you do not successfully program
the HomeLinkt Universal
Transmitter after repeated
attempts, refer to Training a
rolling code
which follows or call
toll-free customer assistance:
1–800–355–3515.
44
Operating the HomeLinkT
Once programmed, the HomeLinkt
Universal Transmitter can be used
in place of hand-held transmitters.
To operate, simply press the
appropriate channel control on the
transmitter (the red light will
illuminate, indicating the signal is
being transmitted).
3. Press the programmed
HomeLinkt control in the vehicle
until the training light on the
garage door receiver turns solid
(1-2 seconds). Release the
HomeLinkt control and repress to
turn off the training light.
4. Press the HomeLinkt control
again. If the garage door activates,
Transmitter has been trained to
the receiver.
Erasing channels
To erase all three programmed
channels:
1. Hold down the two outside
controls until the red light begins
to flash.
2. Release both controls.
Channels cannot be erased
individually, but can be
reprogrammed. Refer to
Programming for instructions.
Oct 21, 2008 | 1999 Lincoln Town Car
Car APS57A Remote Start and Keyless Entry System with Trunk Releas Logo
127 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
