Question about HP Pavilion dv6000z Notebook
HP 6227 BLANK SCREEN
WHEN I HIT THE POWER BUTTON IT THE BLUE LIGHTS COME ON FOR ABOUT 3-4 SECONDS THEN JUST SHUTS DOWN.
    Genius:
  • 1,027 Answers
LINK
The HP DV6000 has problems that HP is aware of. Check to see if yours is eligible for free extended repair.
Posted on May 10, 2008
I push the power button the kocaso screen comes on and tells you injoy colorful life and then goes to a screen that said android for five or six seconds and then shuts off well it does not shut off it...
I used this link and found it had a 50/50 chance of working...
http://forums.androidcentral.com/android-4-1-4-2-4-3-jelly-bean/347622-kocaso-m1066-tablet-system-ui-has-stopped-working.html
I know it's not for your exact model, but manufacturers often have the same method of hard reset for all of their devices. Specifically:
"The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen and you`re done."
Hope it helps u too
Chadman
Dec 27, 2013 | Kocaso M M9100 9-Inch 8 GB Tablet
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
HP Touchsmart IQ526- Black Screen and Amber LED please help! No display. Is this a hard drive issue?
Also had this issue on the Touchsmart IQ526. Removed the CMOS battery, waited some minutes, then powered on. The power button remained blue and had video again. Reinserted the CMOS battery and put the unit back together. Note - the battery was on the mainboard.
Mar 24, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
I used a hdmi cable and lost cable. now cannot use av adapter no picture.
If you have absolutely no picture, hook it up with the av adapter and follow these instructions exactly: Turn your PS3 on with your remote. Note: all of these directions will be with the D-pad on your remote, joystick is not accurate. 1) If you have multiple profiles on your system, just hit X; if you don't, start at step 2 2) scroll entirely to the right. Hold your right D-pad in for about 5 seconds 3) Tap your left d-pad button exactly 7 times. 4) Hold up on your D-pad for 5 seconds 5) Press down on your D-pad exactly 11 times and hit X 6) Hold up for about a second; hit X 7) Hitt the down button 2 times and you'll be over the composite/s-video connector. RED/WHITE/YELLOW. Hit X 8) YOU WILL NOT SEE IT YET, your screen will internally read "Press the x button. The screen will be displayed based on this setting. If the setting is not correct, the screen will go blank temporarily. Then after 30 seconds the system will go back to the previous screen." HIT THE X Button now. This should have it fixed. For step 7, the first one is HDMI, hit down 1 it's component/D-terminal which is the GREEN/BLUE/RED, if you hit down 2x its the component/s-video, and if you hit down 3x it's AV MULTI/SCART. Good luck. Please give me a good rating if I helped fix your problem Respectfully, Don
Nov 03, 2010 | Sony Playstation 3 (PS3) Console
Hi, i just want to know,my hp 550 display is always show me blank(from yesterday),what can i do now?or how can i solv it?pls
Is the display blank when you power on.?
First turn off notebook.Remove battery and power cable.Then hold power button down for 15 seconds.Reconnect battery and power cable.
Try to hit F10 key immediately when you power-on the notebook.
>If you are able to see bios(blue,grey,or white screen) information,then the issue is with windows or with drivers.
>If you are not able to see any screen.Then probably issue with graphics chip on motherboard.Contact Hp for repair options or authorize Hp store.
Thankyou.
Sep 08, 2010 | HP Business Notebook 550
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
HP nc8000 shuts down after 10 seconds
try pushing on the upper right corner of your laptop, above the home key, does it start up again?
If so its the maxim chip
if not take one so dimm out and dissable wireless.
Could also be your battery not charging because a battery or power cord malfunction.
Oct 21, 2008 | HP Business Notebook NC8000
HP Pavilion Dv6000 with Vista screen goes blank
Sounds like a software issue with the power settings for the screen. Go into the display properties, open the tab that reads screen saver, click on the power button. Adjust the screen setting to never. This should take care of your problem, if it doesn't then it may be a loose connection on or around the screen. CHeck the connections.
Jun 19, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
148 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
