Jvc will not power up
Jvc av 36980 will not turn on. Is the 926 capacitor soldered and if yes is this difficult?
  • Dennis Robinson May 13, 2008
    WE DID IT! Bought a capacitor at Radio Shack for 1.79 and a solder kit for 7.99. We are in our 60's with no experience. So maybe it was a little more difficult than it needed to be, but everything turned out fine and our 1999 JVC 36980 is working great. We had to dust the board with a with an artist hair brush to find the numbers. Later we found the capacitor had a bulge in the top, which was obvious. Had we known what we were looking we could of found it quicker. This is a great site, Thank you. We learned how to solder a capacitor on expertvillage.com
    Champion:
  • 230 Answers
Not, just install soldering stations on the terminal capacitor ( bottom) and pull up slow, clean solder and put it back new one. See position ( -- And + )
C926 and C928 1000uf 35v Common problems.
Some time D905 shorted
Replaced C911 470 uf 35V
Ready!!!
Posted on May 11, 2008
  • Noe Z  Bernabe
    Noe Z Bernabe May 13, 2008
    Now ,are you ok?............. Great!!!. Thank you
Jvc tv was one we were watch a show tv shut off and the timer/power light started flashing and clicking
Older model but does have one common failure----there is a 1,000 microfared 25-35 volt cap that opens and causes this---only 2 leads that are soldered and a - and a + to denote which goes where.
If you can solder it is worth a gamble--5 dollar part---The part location from memory is C925 or similar.
11_5_2012_4_21_49_pm.jpgIt will look like this but should be black in color with the 1000 uf and below the voltage rating of 25-35 vdc (volts DC) on it---black band is negative and other side positive.
Nov 05, 2012 | JVC Televison & Video
I have a JVC AV-56P575. The problem is while watching the TV I left the room for several minutes and when I returned it was off. I tried the power button and it would not turn on. I unplugged it then...
Tv DM power supply board might have dying parts like capacitors are bulging or puffing up on it tops.U have tools like a soldering iron,a desoldering pump or a roll desoldering braids and can u also do basic soldering too?Yes.Tries websites like Tvrepairworld.com buy a capacitors set kit put together by them.Tries replaced all dying power supply board capacitors.
Mar 22, 2011 | JVC AV-56P575 56" Rear Projection...
I have a jvc av 36980, wont turn on, replaced capacitor c926, still nothing, fuse is good
Hi, I have same TV with same problem. I replaced capacitor with 1000uF 50v and it worked. I also saw another posting that replaced the SMPS (switch mode power supply) STRF6626 regulator. Radio Shack does not carry it though. I had to order one from an electronics store.
Good Luck....Kim
May 18, 2010 | JVC Televison & Video
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
Will not turn on
Go to the following blog site for detailed instructions on how to fix the TV yourself for around 2 dollars! I fixed mine myself this weekend and I know nothing about TV's. Thanks to this site, I saved hundreds of dollars.
Good Luck...............Kim
Oct 13, 2009 | JVC AV-36950 TV
AV-36980, c926 blown
Electrolytic "CAN" type caps fail for several reasons. 1. over voltage stress. 2. polarity reversal. 3. over current stress. These three things are caused by other components that have also failed or partially failed either before or after C926. Check the rectifier circuit and or the horizontal deflection circuit which gets it's filtered DC voltage from C926. louie12fix on fixya.
Sep 17, 2009 | JVC AV-36980 36" TV
The power button keeps clicking off and on
My set did the same thing. I found the attached blog while I was looking for answers on this website and it explained how to fix the set myself at home for around 2 bucks!!! I tried it and it worked!
Good Luck...Kim
Aug 30, 2009 | JVC AV-36950 TV
Jvc av 36950 went off while watching, the same sound that you get when you turn set off. No sound, no picture, no red power light
This TV has a common problem. I've found dozens of owners with the same complaint. See the following blog for a simple fix for your set. I tried it and it worked and I spent under 2 bucks to fix it myself at home!
Good Luck......Kim
Dec 09, 2008 | JVC AV-36950 TV
No power
Replaced the C226 capacitor. Using advice from this web site, found the capacitor, and yes it looked burnt, went to Radio shack and for $1.69 bought a new one, put it in, and we were all set. Does have to be soldered in, in all it took us about 1 1/2 hours. Thanks for the tip.
Sep 21, 2008 | Televison & Video
Jvc tv no power
relace capacitor 926, 1.50 from radio shack
May 31, 2008 | JVC AV-28-BD-5-Bl 28" TV
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
