My rca model d52w135d picture does not come on only the sound. Every once and a while the picture will come on and when it does it works fine.
  • 5,807 Answers
On some it is caused by a Resistor
http://www.fixya.com/support/t4109206-rear_projection_tv_rca_d52w26_whith
on the Deflection Board
It could also be fault on other components like
symptoms of having
a partially shorted Flyback
These troubleshooting applies only if you can DIY
or have a friend to assist you in troubleshooting
These also applies if you have a knowledge on the
circuits which I have mentioned above, and a
starting guide for a pro.
On some it is caused by cold solder joints but
one has to check on it to confirm.
One has to check starting from the power supply
to the Horizontal deflection Circuits .
Should you need more details let me know to resolve
the problem you are having.
Regards,
palaboy
Posted on Sep 03, 2010
Got sound and can change channels but no picture
Make sure your cable wire is hooked up correctly and screwed in all the way as well as all the other wires on your cable box
Dec 18, 2012 | RCA D52W135D 52 in. TV/DVD Combo
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
It goes off and u can get it back on ,,you have to keep turn it off and on before it will ever come on and stay.. lots of bad reviews on this brand RCA model D52W20 SHOULD BE A RECALL ON THIS BRAND TO...
RCA Scenium HDTV (Model #: D52W135D)(Chasis # ATC221) WILL NOT TURN ON!! When plugged in after a while of being unplugged the front power light will flash green lights first once...then 9 more times. I can hear the static in the back but nothing will turn on. It really sucks becuase we were just watch yesterday, turned it off after a while of it being on(I don't know if that matters) then the next day in the morning I tried to turn it on and it wouldn't turn on... :Z PLEASE HELP!!
Feb 16, 2011 | RCA D52W135D 52 in. TV/DVD Combo
Turned tv on and it has no picture but sound works fine
This problem is due to loss of high voltage in your tv. Without it the CRTs won't power up and hence there will be no picture. Most common causes of this problem are damaged flyback, HOT(Horizontal output transistor) and/or Horizontal/Vertical deflection circuit. If you have prior experience in handling high voltage electronics I can guide you with the repair. Otherwise its best left to a tech. 30,000V is not to be messed with.
Jan 27, 2011 | RCA D52W135D 52 in. TV/DVD Combo
Out of focus
Sounds like you have multipath distortion.
That means the radio waves are bouncing off something and you are getting two signals arriving at slightly different times.
Jul 19, 2010 | RCA D52W135D 52 in. TV/DVD Combo
Got and RCA Scenium CRT HDTV (D52W135D) which seems to have a convergence problem, green shadow over picture. DVD picture is very dim also
This tv have 2 problems than,the tv projection lamp life is over,that why the picture is dim,must be to replaced with a new picture lamp.The tv convergence board the 2 STK convergence ICS and some or all the resistors are dead.Replaced all these parts to solved the convergence problems.
Jun 24, 2010 | RCA D52W135D 52 in. TV/DVD Combo
I have a RCA Scenium D52W135D, that wont come on. every great once in a while it will. When you plug it in it starts to warm up then shuts back down. Keeps repeating. It flashes a code at you through the...
have scenium d52w135d combo burnt power resistor in deflection board,do i need to replace the the whole board? or just the resistor,and where can i find this resistor?
Nov 03, 2009 | RCA D52W135D 52 in. TV/DVD Combo
Have sound no pic. on 52 inch.
if you have some thin lines on the top of the picture probably you have a problem on the power supply for the convergence
Sep 29, 2008 | RCA Scenium D40W20 40" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
