Question about Canon Elura 70 Mini DV Digital Camcorder
Cannon Elura 70
When I turn my camera on it does not show what I am pointing the camera. The power is on, lense cover is removed and is set in the camera mode.
  • dummyaccount Aug 26, 2008
    Same issue. Prior to this I had the zooming-in issue you can find people complaining of on this site. More complaints to Canon increases the chances they'll do an out-of-warranty repair for us, so please contact them with your complaints!
I have one of these too and unfortunately they have many bugs. Every time I have a problem with my camera I just have to bang on it a little bit or wait out the problem. I have read too many forum entries with people saying they have sent it back and not received proper help. I just wanted you to know you're not the only one out there! Good luck.
Posted on Jun 25, 2008
I have a Canon Elura 70 with the same problem as above. The viewfinder is black when the camera is turned on. The cause of problem was a hit with a baseball on the front of the camera. How do I contact ...
HI there during hit on the camera by ball your camera mechanism disturb & thats why you face this problem. Please visit service center for repair the camera. Thanks.
Feb 18, 2011 | Canon Elura 70 Mini DV Digital Camcorder
Will a Sigma DL Macro Super 70-300mm 1:4-5.6 Lens fit my Nikon D80?
All after market lenses are specifically designed for a brand of camera. They are for Nikon, Cannon, Minolta etc.. They can not be cross branded just as you could not use a Nikon made lens on a Pentax.
Oct 09, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
WILL THE ABOVE LENSE WORK WITH A CANNON DIGITAL CAMERA AND CANNON 35MIL CAMERA
Yes, it's suitable for 35mm EOS mount Canons and all digital models. If the digital SLR has an APS-C sensor then the image will be cropped and will give the same viewing angles as a 112-480mm on a 35mm camera.
Oct 03, 2010 | Canon EF 70-300mm f/4-5.6 IS USM Lens
How do you get videos from a cannon elura 85 onto iMovie?
Use wall power, not battery power. Set camera to Play (not PC Connect)
Open iMovie, wait a minute or so for import screen. If it does not come up, click the camcorder button.
Apr 10, 2010 | Canon Elura 85 DV Digital Camcorder
Windows Vista doesn't recognize camera
well, first, u should check what format of the video file from your cannon. In my opinion, it may be mod format, and vista and lots of players will not support mod. u should try to convert mod to some regular format .
Oct 04, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Looking for a manual
I coulnd't find a manual. I did see a detailed specification page here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=150&modelid=9996#DownloadDetailAct
It shows no manual is available for the lens.
Jul 18, 2009 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
My cannon elura 70 got wet and now it will not power up or eject the tape even after it appears dry. Anything simple I can do before I bring it in to have it checked out?
Since the post date appears to be 7/16/2009, I would open it in a dry place and blow dry air over it to ensure it is completely dry. If the camera was very clean before it got soaked, it may recover. If it was dusty or had been in "bad" environment, the water might have carried crud into the camera mechanizm or into the electronics.
Try to dry and then report back!
Vidron
Jun 16, 2009 | Canon Elura 70 Mini DV Digital Camcorder
Quantary Tech-10 75-300mm use with Canon Rebel XTi
Hi all
On most lenses the way to test if your old lens works on a cannon digital to set the camera to AV then set the iris to the small setting ie F16/F22 then use the stopdown button.
Things that might happen
1 The lens will close down OK
2 The error 99 will show,will need are rechip if avaliable
3 Nothing happens, will need a rechip
Q.Why will it work inside but not outside.
A. Inside the camera needs light so the iris is full open, outside the lens needs to close down and if not compatible it is unable to close down. will need a rechip
Mar 12, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 for...
Won't take a picture
how cold - it may be a chip problem on the 70-300 whats the lense make/model that works and lens make/model that only works when warm
Apr 13, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon Elura 70 Mini DV Digital Camcorder Logo
81 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
