Question about Panasonic SC-HT75 System
Locked when you try to open the dvd palyer it says its locked
  • Anonymous Apr 30, 2009
    It displayed "Locked" and won't eject.
With the unit switched on press and hold the stop button and press the power button once. if that doesn't work then try it with the play button.
Posted on Jun 12, 2008
  • 3 Answers
Just hold the eject button down for 10 seconds
Posted on Jan 07, 2009
Dvd can not open
Maybe you should try to open the DVD with another program. I know VLC media palyer can play DVD. Also it is free. very powerful program. Just try.
Nov 05, 2013 | LG Televison & Video
How can i watch to my dvd player my burn in my dvd r
hi, you install VLC media Player/ Windvd /GOM player. Then Insert DVD into your DVD drive.After that open My Computer and select DVD drive and open with VLC/ Gom?Windvd palyer.
Thanks.
May 15, 2011 | Computers & Internet
Dvd palyer cd drive open not close no romote & dvd munual & no cd play
hi,
can u explain the problem in briefly. the only u will get a better solution
ok
Jan 11, 2011 | LG RH177 DVD Recorder/HDD Recorder
Dvd drive door won't open
You may have a damaged DVD. Try turning the power off. Look for a small hole in the front of the DVD palyer. You can usually stick a pin in there to release the door. Take out the DVD and try a different one.
If there is no DVD, the device may be disabled in WIndows. Two other causes could be that the power plug on back of DVD is off or the data cable is on backwards. If the DVD worked before, these are unlikely.
Mar 02, 2010 | Philips DVDR3455H/37B
Tray lock on pioneer
press and hold stop button on the front apnel on ur dvd palyer ur palyer will resetting
Jan 26, 2010 | Pioneer DVR-225-S Pure Cinema Home DVD...
DVD WILL NOT OPEN - DISPLAY SAYS BLOCKED
press and hold stop button on the front panel on the dvd player more then 10 sec.ur palyer will be unlocked
Jan 26, 2010 | Philips DVDR80 DVD Recorder
When I start the movie the screen is dark and there is no vertical hold on the cyberhome screen
ur palyer is progressive mode u cahnge normal mode.press and hold stop button on ur dvd palyer front panel
Jan 26, 2010 | Cyberhome CH-DVD 300 DVD Player
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
I have a dell dimension e310. i think my 2 year old daughter did something to the dvd /cd player and it will not open. i would like to try to replace it myself but i have never opened a pc. how do i go...
Most CD unit have a small pin hold where the cd table comes out, stick a paper clip in and see if the door opens, there may be a jamed cd in there. To change, unplug machine, remove covers, first install what you have such as one dvd r/w or a CD rw/DVD reader. from back unplug power plug, only goes one way, your data cable, keyed only goes on one way, and possible speaker audio wire. scres on side, or clips that hold cd unit in machine, Some pull out from front and others from rear. Check settings on back of old CD R/w as to s (slave) or M (master. set new to same configuration. install, reattach wires - power - data and sound, install screws or clamp. plug power in and reboot. Machine XP or Vista should find new unit. Some replacment DVD/Cd units come with drivers. install if needed. Easy repair, don't worrry. Good luck. Anouth tip if CD is locked in old machine, turn upside down and try to open CD, sometimes the lodged CD falls in place.
Jun 23, 2008 | Computers & Internet
Panasonic SC-HT75 System Logo
222 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
