Question about Thunder Tiger Scooter ARF R/C Airplane
I got 1 2nd hand thunder tiger ssk, only been used handful of times, after a while the clutch slips real bad, but after cooling down it`s ok, can it be adjusted or does it have to be replaced?
My 1999 ford RAnger has heat but the fan makes alot of noise and does not blow out the heat and the trucks gauge will go hot. What would the issue? Heater core or mayb just the fuse?
Diagnose Cooling Fan Clutch On engines with belt-driven cooling fans, a fan clutch is often used to save energy and reduce noise. The fan clutch disengages slows or disengages the engine's cooling fan when extra cooling isn't needed. The fan pulls air through the radiator and air conditioning condenser when the vehicle isn't moving fast enough to provide adequate airflow for cooling. A fan can eat up anywhere from a couple of horsepower up to 12 or 15 hp on a big V8, so by reducing the parasitic horsepower loss on the engine the fan clutch makes a noticeable difference in fuel economy
TWO TYPES OF FAN CLUTCHES basic types of fan clutches: thermal and non-thermal (also called "torque limiting Thermal fan clutches have a temperature-sensitive bimetal coil spring on the front that reacts to temperature changes. When the air coming through the radiator is hot, the spring expands and opens an internal valve that reduces clutch slippage. This causes the fan to spin faster for increased cooling. As the air cools, the spring contracts and closes the valve. This increases the amount of clutch slippage, allowing the fan to slow down and decrease cooling FAN CLUTCH OPERATION
The clutch consists of a fluid coupling filled with a silicone based oil. In the cutaway view at the left, the area between the teeth on the clutch plates is filled with silicone fluid. An internal valve opens and closes a passage between the main fluid cavity and a fluid reservoir. When the passage is open, fluid enters the clutch and makes the fan to turn faster. When the valve is shut, fluid flows back to the reservoir but doesn't return, causing the clutch to slip and the fan to turn more slowly.
The non-thermal (torque limiting) fan clutch doesn't have a temperature sensing capability. It reacts only to speed, slipping to limit maximum fan speed to about 1200 to 2200 rpm depending on the application.
FAN CLUTCH PROBLEMS
A slipping fan clutch is often overlooked as the cause of an engine overheating problem.
As a fan clutch ages, fluid deterioration gradually causes an increase in slippage (about 200 rpm per year). After a number of years of service, the clutch may slip so badly that the fan can't keep up with the cooling needs of the engine and the engine overheats. At this point, replacement is often necessary.
Other signs of fan cluch failure would include any looseness in the clutch (check for fan wobble), or oil streaks radiating outward from the clutch hub.
If the clutch is binding, the fan may not release causing excessive cooling and noise, especially at highway speeds
CHECKING THE FAN CLUTCH
A good clutch should offer a certain amount of resistance when spun by hand (engine off, of course!). But if the fan spins with little resistance (more than 1 to 1-1/2 turns), the fan clutch is slipping too much and needs to be replaced.
If the fan binds, does not turn or offers a lot of resistance, it has seized and also needs to be replaced.
Fan speed can also be checked with an optical tachometer, by marking one of the fan blades with chalk and using a timing light to observe speed changes, and/or listening for changes in fan noise as engine speed changes.
You should also try to wiggle the fan blades by hand. If there is any wobble in the fan, there is a bad bearing in the fan clutch, or a worn bearing on the water pump shaft. A bad water pump bearing will usually cause the water pump to leak and/or make noise, but not always. Remove the fan clutch and see if the play is in the water pump shaft. If it feels tight (no play or wobble), replace the fan clutch.
FAN CLUTCH REPLACEMENT
Many experts say it is a good idea to replace the fan clutch at the same time as the water pump if the water pump has failed. The reason is because both age at about the same rate, so if the water pump has failed, the fan clutch may also fail soon. As as we mentioned earlier, a high mileage fan clutch may be slipping excessively increasing the risk of overheating.
When you buy a replacement fan clutch, make sure you get the same type (thermal or nonthermal) as the original. You can always upgrade from a nonthermal to a more efficient thermal fan clutch, but never the reverse. Or, you can get rid of the fan and clutch altogether and install an aftermarket electric fan kit to cool the radiator.
Sep 28, 2016 | Ford Cars & Trucks
What does ssk mean in knitting and do you have a list of different meanings for kniting
Slip slip knit or SSK is a basic way to decrease stitches. It makes a decrease that slants to the left and is often paired with knit two together, which is a right-slanting decrease.
To execute this decrease, slip the first stitch as if to knit, slip the second stitch as if to knit, then slide the left-hand needle into the front part of both stitches and knit them together.
Oct 21, 2014 | Sewing Machines
Hi have an 88 cbx750 f2 the sprag in the slipper clutch is slipping, installed 2nd hand low mileage unit , better but still slipping above 6000rpm at times
Most of my friends with 88 slipper clutches spray paint their rims black, and it seems to help. One guy actually put new springs in his. Clutches slip because the friction material is worn out or the springs have lost their tension or their spacers. Put a washer on all the spring bolts and see if that helps, if it does, get new springs.
Sep 27, 2014 | 1988 Honda CBX 750 F
My 2000 ford focus does good, til i change into 2nd gear, then from 2nd through 5th gears, it jerks and barely runs. and when it gets real bad, it causes the clutch to slip, what could be the cause of...
So you can race the engine in neutral, and no problem with it trying to die? If that's so, I think you need a clutch job. A clutch disc contaminated with oil or grease will cause jerking and slipping.
Sep 14, 2012 | Ford Focus Cars & Trucks
How to drive?
you can ride the cluthch on a bike un like a car you wont hurt it its oil lubricated constantly, sitting on the bike pull the clutch in with your left hand and click the left foot lever down in to 1st, then learn how to click it back up 1 half movement in to neutral. the neutral light will come on sfter the bike enters neutral. in first gear give the throttle on the right hand a squeeze and pull the clutch in with your left hand put foot gear selector down in to 1 st and begin to release clutch slowly. hold on as bike will engage may be jerky balance yourself! when you get moving stop! by pulling the clutch in and the hand brake as you close the throttle to stop! practice your take off many times some where safe! when you get your balance in 1st gear pick up speed and begin shifting the foot gear selector up in to 2nd gear and practice closing the throttle and breaking to a safe stop. gears are generslly 1st down 1 click 2345 and6th all up from there and neutral is 1 half a click up from 1st between 2nd gear. And dont put it in gear with the kick stand down t may stall on you
hope this helps
May 03, 2011 | Honda CR 500 R Motorcycles
Spin cyle wont spin unless i start it by hand. then it will spin until rinse then i have to start it again with by hand.
Assuming that this washer is agitating properly and your only concern is spin you have a bad clutch that has been contaminated with water or grease or is just plain worn out.In either case the clutch is slipping to much to start spinning on its own. Not a real bad repair but something most homeowners would not repair themselves.
Sep 16, 2010 | Kenmore 24032\24036 Top Load Washer
I need to remove the crankshaft so that I can take the timing bel
Ummm, most of them have a standard right hand thread, they use a key so the bolt doesn't have to fight torque, just hold the clutch on, then look inside, they usualy have a coarse thread 5/8 right hand NC cut into the clutch to remove. but I must ask why do you need the clutch removed
if it's slipping or locking up, it's NOT the clutch the compresor's bad.
If the pulley has the wrong belt then go ahead.
Aug 29, 2009 | Heating & Cooling
Thunder Tiger Scooter ARF R/C Airplane Logo
Top Thunder Tiger Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Thunder Tiger Toy Expert? Answer questions, earn points and help others
