Question about Asko 1375 Dishwasher
Dishwasher begins to fill then stops with no further progress.
  • Asko Master
  • 2,605 Answers
Welcome to FixYa.
Based on hoe you`ve described the issue with your Asko, initially it sounds like a faulty inlet/water fill valve...
But, I`d like to clarify the symptom first. Does the unit complete the fill cycle and then do nothing, or it just energizes the fill momentarily then does nothing ?
Also I will ask to verify the model is an Asko 1375 ?
I`l watch for your reply.
Regards,
Macmarkus :)
Posted on Sep 02, 2010
The washer will not wash
I have the same problem as of yesterday May 1, 2010. I can move the water pump on the bottom and it comes on and begins to wash but it acts like it is in a bind. I tried to check to see if something was in it but i could find anything that might hang it up.
May 01, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My GE Nautilus dishwasher takes water in and then stops and nothing happens. I tried flusing it with hot water and vinegar and no progress. Any ideas are very welcomed. Thank you.
Flushing the hose with hot water and vinegar would not help.
If the machine is filling and then stops, parts that may be responsible are the impeller pump and the control board.
If the machine is under filling, test also the floater switch.
If the water is not warm, check the heating system or the hot water supply.
If this machine has dual inlet, test that both solenoids are opening.
Dec 02, 2009 | GE Dishwashers
The dish washer fills and wash cycle begins, however stuck at wash does not progress to rinse cyle
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 03, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Item: Whirlpool Ultra Dishwasher Age: 3 yrs Problem: Not enough water to effectively wash the dishes. State: When the dishwasher is started, the fill valve opens as normal. Only about 1/2 the amount of...
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Oct 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE model GSD600003 repair manual: Before you answer this, please tell me if I will be charged for the answer, in case I'm not interested at this time. Do you have a diagram of the drain area and water...
I'm not sure how mildew can grow in a dishwasher that is working well, but after cleaning it and putting things back together, it does now seem to be working. I thought that the water wasn't filling but I guess the heating element heats up before the water fills the dishwasher. So when I tried again and started the dishwasher from the beginning and waited, it did progress to filling water and going through the whole cycle.
Oct 18, 2009 | GE Dishwashers
Dishwasher wont progress to next step
Does after the manual moving to the next step, the dishwasher complete the cleaning process properly ?
May 16, 2007 | Bosch 22 in. SKT5102 Free-Standing...
Asko 1375 Dishwasher Logo
312 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
