Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
"Lens not attached" warning when lens is in fact attached.
Haven't even had the camera for over two months. Suddenly after normal use the camera gives me a problem stating "Lens not attached!" on the settings screen. It will take photos in Manual mode, but camera is not detecting lens. Have tried removing lens, cleaning connections, etc. with no luck. Using standard Nikor 18-55mm lens.
  • 2 more comments
  • Anonymous May 25, 2008
    Same issue. "no lens attached after 2 months
  • lillejhon Jun 05, 2008
    6 months old camera gives note with 18-35mm G2 lens not attached. Camera will work OK on M with this lense; separate telepoto lens works OK.
  • Anonymous Jun 10, 2008
    Same here only 2 days out of the box. Works fine with the telephoto but standard lens gives the error message.
  • ion_alen Oct 12, 2008
    I just received this error message. I changed the lens with a new one but same results.
    Problem Solver:
  • 6 Answers
Hello. Check the area around the lens mount carefully - specifically the contacts. Make sure all are clean and protruding the same. If one is lower than the rest, try 'flicking' it with a fingernail (lightly) to see if it will pop up to the height of the others. It may have dirt or a particle of dust lodged. If this doesn't help, get the lens to Nikon for a check-up.
Posted on Jun 06, 2008
    Problem Solver:
  • 8 Answers
Sorry guys dont mean to seem smart but if it is in warranty bring it back to where you bought it. Its their job to fix it.
Martod
Posted on Jun 12, 2008
DSLR says lens not attached
Hey there,
It sounds like your problem is related to the aperture setting on your lens. The aperture ring should be set to the smallest aperture usually f22 when attaching these older lens. Most lens aperture rings will provide a locking mechanism for that ring on the lens.
The aperture would be then set through the camera, not on the lens. Also some nikons have a lens preset on their menu, where you can inform the camera which lens is attached. Most of the older lens lack any terminal points for communicating with the camera automatically, therefore you will have to fill in the data manually to get better functionality out of the lens camera combo.
Sep 25, 2013 | Nikon D3200 24.2 MP CMOS Digital SLR with...
Hi. I have Sony a100 slr camera and Minolta 28-100 lens. One day the camera suddenly said that lens is not attached and wont make any shot.
Remove the lens and clean the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
Jun 14, 2011 | Cameras
It doesnt open suddenly for no reason
When you turn the camera on do you hear the motor trying to extend the lens? if yes! get a can of compressed air and attach the included straw, give it a good two or three blasts where the crevice of the lens and body meet, at the same time press power to see if the lens housing can breaks free to extend. If this works point the lens down, and run the cycle three or four times to work any grit that might be trapped.
Jan 23, 2011 | Canon PowerShot SD1100 IS Digital Camera
About 2-3 months ago my camera suddenly said lens
If it says lens error all you have to do is try pushing the lens back in. If that doesnt work, sorry! lol =(
Oct 10, 2009 | Canon PowerShot A710 IS Digital Camera
Lens error: canon sx110is
I had the same thing happen to me and didn't use my camera for about two months. One day I decided to gently hit the side of the lens and the side of the camera closest to the lens as well. I still can't believe it, but my lens suddenly popped open and has been working fine ever since. Before this nothing had worked, including the gentle hitting of the side of the lens I had done before. I think I hit, or I should say thumped, the side of the lens a bit more forcefully this time. If your desperate, you might want to give it a try but make sure you keep thumping hit for a while before you give up. I think it dislodged some small particle that had been blocking the lens from opening up.
Apr 08, 2009 | Canon PowerShot SX110 IS Digital Camera
Nikon AF 35-135 lens
Did the only the lens drop or was the lens attached to the camera body? If the lens was attached to the camera, you need to verify that the problem is in fact the lens and not the camera body. The easiest way to do that is to try a different lens on your camera body or your lens on a different body. If you do not have access to either, I would find a local camera store that sells Nikon equipment. I am sure they will let you put your lens on one of there bodies. In any case, ff the damage is as extensive as it sounds from your brief description, you need to take it to a camera repair man. This is not a do-it-yourself job.
Feb 07, 2009 | Nikon N70 35mm SLR Camera
Wobbly lens
Half mm or so movement is normal in fully extended lens. If camera is not giving any error display during function then every thing is just fine in it.
Feb 04, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Says lens error!!!!!
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Apr 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
963 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
