Question about Refrigerators
I'm looking for new door seals for Model #GT19X7V (Magic Chef)
  • 1314 Answers
SOURCE: Fridge does not get cold enough
first the freezer does all the cooling there are air vents in top of the refrigerator that the evaporator fan draws air through then blows it down to cool the fridge in the fridge section you should see an air vent if you don't have a defrost problem then you have an air flow problem first do you hear the fan running if you see heavy frost on the back wall of the freezer wall where the fan is then you have a defrost problem and that's a different repair but if you don't then remove the four screws and pull the panel carefully as the fan is there see if there is heavy frost on the evaporator a large aluminum honey comb so much that air cannot come through it under that part will be an a tray with around hole in it make sure that's is not frozen and the drain hole is open then check that the square hole that goes down to the fridge is clear and check the two square styrofoam intake blocks are clea you an pull them out gently and see if its iced up under there after you check that reply to me on any fault
Posted on Dec 31, 2007
SOURCE: New magnetic molding on refrigerator not working.....
Use a hairdryer all around the gasket to soften the vinyl then "twist" the door until you get a good fit. Leave the door shut and switch to "cool". Don't open the door until the gasket is at room temp. Tighten screws all around in random order. Repeat if necessary. In severe cases it might be necessary to "shim" the hinges out just a bit with cardboard.
Posted on Jan 08, 2008
  • 172 Answers
SOURCE: Power Consumption - Magic Chef Wine Cooler
The unit will draw between 6 and 12 amps on start up and running it should use less than 1.6 amps. The start up amps will increase with age. Funny how that works the same for people as it does for machines. I hope this will FixYa. Please dont forget to rate. Mike
Posted on Sep 24, 2008
  • 3 Answers
SOURCE: I have a Magic Chef Ice Maker Model No. MCIM30TS. My problem is that when I plug it in, nothing happens and the power light is blinking. Is the unit shot? Andrew from New Jersey
Hi, It's supposed to do that. Fill the base with water, then select an ice cube size, then click "start". It should start making ice within 20-30 minutes. The power goes off here all the time and that's how we re-start the machine. The important part is to first select the ice cube size, then click on "start'. I have no idea why it has to be done in that sequence. I have the same model, only I got it two years ago.
Posted on Jun 26, 2009
  • 82 Answers
SOURCE: Magic Chef Refrigerator door flys open
Sounds like you have the unit out of level front to back leaning towards the back. Try leveling or just tilted a little with the top leaning just a little toward you. This should keep it from flying all the way around.
Posted on Jun 28, 2009
WHATs the equivalent of a door gasket for this magic chef refrig?
get the right one from the spares deaprtment of the service shop
There are people like "Door Seal" or fridge seal replacers who can make a seal on site to fit the door
May 12, 2015 | Magic Chef Refrigerators
HOW DO I REMOVE THE LOWER ELEMENT OF A MAGIC CHEF STOVE OVEN
What is the complete model number of your unit? Look inside the door area.
Nov 28, 2012 | Magic Chef Kitchen Ranges
MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8 CU FT UPRIGHT FREEZER MCUF88W -- BRAND NEW JUST BOUGHT?? HELP
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
Sep 27, 2010 | Magic Chef 11.8 cu. ft. / 334 liter...
I found a water pool on the floor...
a coupltle thinges ,ur het plate to evaporate condensation it out, ur low on collant, or door sel is not sealing
May 30, 2010 | Magic Chef CTB2125 Top Freezer...
The spring mechinism which automatically closes the door on my under counter Magic Chef dishwasher has failed. How to fix it?
call your nearest appliance parts store with you model and serial # and ask them to look up the door handle/latch mechanism assembly and replace it.
Oct 11, 2009 | Magic Chef Dishwashers
What would cause the inside top of a Magic Chef refrigerator model RBK21K-2A to freeze up and not keep items in the refrigerator compartment cold (temp doesn't drop below high 40s)?
lack of sufficient air flow across the evaporator coils, clogged condensate drain, too much humid air (door open too much, bad seals, etc.), low refrigerant.
Aug 07, 2009 | Magic Chef Refrigerators
I have a Magic Chef refrigerator Model CTB1925GR and I need to adjust the freezer door(raise it on the right so that it seals properly
On the top of the refrigerator is an adjustable hinge. You may have to pop of a cover plate to access the screws to loosen, make your adjustment and re-tighten.
May 17, 2008 | Magic Chef Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
