Question about Kenmore Elite 45986 Front Load Washer
F21 Code on my frontload washing machine - Kenmore Elite 45986 Front Load Washer
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
The "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump is being obstructed by debris or some other foreign object as opposed to being faulty, although that can`t be ruled out...yet.
Here`s how to check it and clean it...
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the drain hose, hose from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
macmarkus :)
Posted on Sep 02, 2010
    Top Expert:
  • Kenmore Master
  • 76,164 Answers
This code indicates a clogged or obstructed drain, chech your user manual for instructions on cleaning the drain at the pump inlet, it is behind the front panel of the washer.
Tip
Whirlpool frontload F2, F21, Sd and suds error
Sorry, FixYa seems to have made it impossible for the novice internet user (such as myself) to alter or edit my tips to my satisfaction so I have removed it. Sorry for any inconveniences.
Hope you will find what need elsewhere.
Macmarkus :)
on Apr 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi there My frontloader washing machine display
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock.
Mar 08, 2011 | LG WD-1280FHD Front Load Washer
My frontload washer keeps saying f21
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Feb 27, 2011 | Washing Machines
I have a whirlpool frontload washer with model number WFW83005W00 and I have an error code F21 that flashes and then the washer stops working. What does this mean and what should I do?
Means the drain is taking too long . Most likely that the drain sump filter is blocked. Remove the lower front panel and unscrew the large white thumb screw attached to the pump. Water will come out so collect it then clean and replace.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F21 on the Kenmore HE2 Plus Frontload Washer
there is a removable access panel on the front of the machine under the door. Remove one screw from each side. There you will find the pump that has a strainer basket on it. Remove that and clean the blockage out of there. You will also find attached to the panel, another manual that explains the codes better
Dec 27, 2009 | Kenmore HE2 Plus Front Load Washer
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet f21 and d5 codes
You have me there, my book I learned from doesn't show any d codes.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F21 error on a whirlpool frontloading WFW8300
error code f-21 is a simple fix on the front of your washer there is a lower panel that can be removed
with three screws. after removing panel you will see a white plastic piece/plug that you can unscrew
(be prepared for water spillage) remove that plug this is called the coin trap clean out this trap and put back together. this should solve your problem
Jun 21, 2008 | Whirlpool WFW8300SW
Kenmore Elite 45986 Front Load Washer Logo
56 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
