Question about HP OfficeJet 6110 All-In-One InkJet Printer
Copy problem The top loader on my officejet 6110 all in one will not load the paper for copies.Wen I try it says reload paper.
  • 21 Answers
Try cleaning the pickup rollers and seperation pad with oil like WD40 or even acetone, thiswill probably help. If not, you have a blue plastic strip behind the roller mechanism. Remove this strip and make sure that no paper or staples etc are jammed there.
Posted on May 11, 2008
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
HP all in one printer 6110 Computer says printer is out of paper, but printer doesnk't show any error messages. I have unplugged it and re- set it. It does have paper! I can copy a page from the top...
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Hope this helps. Please rate my response.
Have a good day.
Feb 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My officejet 6110 wont make copies paper comes out blank
Check your ink, go into maintance and run some ink tests.
Sep 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Will not copy
The machine is falsely reading that there is paper in the Automatic Document Feeder. That is why it is saying "Original Loaded" before you put the paper on the glass. When you hit Copy, it is trying to pull paper in from the ADF, when it doesn't get any, it reads "Reload Document" because it thinks there is a jam. There is either something stuck in the ADF causing it to trip the paper sensor, or the paper sensor is broken or dislodged. Open the top cover of the Auto Feeder and look for a small black piece of plastic that looks like it moves back and forth when paper hits it and see if there is anything wrong with it.
Hope it helps!
May 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One... Problem copying
check the settings, it may be set to some other that letter.
Mar 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Original document stuck in feeder of HP OfficeJet 6110 All-In-One
ok...this is not that'll need to open up the top of the machine, and most likely remove some components. Take a look at this link first though Got backup?
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
All in one printer
This seems to be a paper registration problem for the copy function only that is an HP thing Good old HP so innovative and so secretive none of us know whats going on most of the time. Two things to try. Take the stack of paper out of the feed tray and riffle so that it is slightly 'untidy' switch off the device , load the paper, switch on- see what happens. Next look at the software disk- there is usually a fully comprehensive reference manual on there [more than in the book]- check that out then come back.
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Black lines on scanned copies
Try this. Lift the lid to expose the top glass. To the left of the main glass panel, you will see a narrow glass strip. Clean this strip using a soft cloth or sponge moistened with a nonabrasive glass cleaner, then dry it off with a dry chaois cloth or cellulose sponge. A.
Apr 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
