Question about Jabra BT350 Bluetooth Headset Headset
Trying to charge my headset after not using for uite some time. No indicator lights. Is it the charger or the headset? Worth trying to repair, or just buy a newone?
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
Posted on May 19, 2008
  • Bigbob351 Feb 27, 2011
    I have jump sarted units this way with just a common D Battery and it works fine.
Im trying to connect my Jabra BT350 to my blackberry 8520 but my blackberry bluetooth wont even find the device even the Jabra headset is turned on.....i also lost my Jabra BT350 user manual cd and i dont...
The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
Aug 29, 2010 | Jabra BT350 Bluetooth Headset Headset
I do not have my manual to sync my bt350 with my new phone how do I do this?
Before you use your Jabra BT350, you need to pair it with your mobile
phone.
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 5)
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’
or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4
zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
hope this helps
Jan 30, 2010 | Jabra BT350 Bluetooth Headset Headset
I charged the BT350 using the Jabra Charging
I called Jabra Support and they are sending out another unit. The technician indicated that the battery is likely defective and is not field replaceable.
Thank you,
Dec 11, 2009 | Jabra BT350 Bluetooth Headset Headset
An old headset I had would flash blue and orange when it was in discover mode, ( so the cell phone would find it to pair it up). This jabra I have will not go there. My cell phone just says cannot find...
Hello friend,
First, make sure that your headset is charged and then press and hold the "Answer/end" button until that the light becomes blue solid. at this time you can do a search on your phone to discover bluetooth devices.
Here is the link to download the user manual for more information:
if the device doesn't light on at all, you may need to try with another charger because in this the device is not charged at all.
Best Regards,
Oct 30, 2009 | Jabra BT350 Bluetooth Headset Headset
My jabra BT350
trying to pair my jabra to my lg vx8350 phone
Oct 06, 2009 | Jabra BT350 Bluetooth Headset Headset
New jabra 350 can't be charged
right out of the box i had the light flicker on me too. if you don't have warranty or receipt like i did try this. i'm not responsible if it doesn't work after!
peel off the blue part of plastic that has jabra on it. take a screwdriver and unscrew the star screws. take the cover off. using some wires, briefly connect a battery (i used a wireless drill battery) to the leads of the bluetooth battery. you'll see a spark.
now my thing is charging for the first time
May 24, 2008 | Jabra BT350 Bluetooth Headset Headset
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at jjkernaud@hotmail.com
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
527 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
