Question about Frigidaire Affinity ATF7000E Front Load Washer
Error code ef1 clothes are still wet after spinning also gives errorcode e20
SOURCE: Error code 20
Knexsen's solution worked for me, but being lazy I took a shortcut. Instead of completely disconnecting everything from the black rubber assembly that contains the filter basket, I just disconnected it from the pump. Within the main body of the assembly I was able to work the filter basket around until the top of the basket, which is open, was visible through the opening that leads to the pump. With a pair of needlenose I was able to remove the object blocking the filter, which in my case was a sock (and to think, all these years we've been blaming dryers!).
Speaking of dryers, mine is stacked on top of my washer, but I was able to safely tip the whole works forward (good suggestion, that) with the use of brace between the dryer and the nearest wall.
Posted on May 31, 2008
onthejob5130
  • 640 Answers
SOURCE: E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Posted on Jan 31, 2009
  • 4 Answers
SOURCE: not draining all the way. slow spin
I had the same problem.  There was a sock stuck in my drain hose!  To correct it, I did the following:
  1. I removed as much of the standing water from inside the drum as possible (a siphon is handy here, otherwise you're just slinging buckets).
  2. Then, I removed the front panel.  On my unit, there were two screws holding it on towards the bottom.  I removed the screws and the panel slid straight down and I could pull it away from the unit.
  3. Then, I located the drain hose leading from the drum.  I put some towels around it to catch some of the leftover drum water.  It was a lot of water and a catch bucket would have been a good idea, too.
  4. I removed the drain hose from the drum by squeezing the clamp ends and sliding it down the hose a bit.  Then I could easily slide the hose from the drum.  Splash!  Water came rushing out.  So, at his point I knew the clog happened after the drum.
  5. I then removed the other end of the hose from the electric unit (I don't even know what it is).  Voila!  A sock!  I pulled the sock out and replaced the hose.
  6. I ran a rinse cycle to find there was still something else besides the sock stuck, so I suggest you check the area thoroughly while you have it apart.
Hope that helps you!  I feel good I spared myself a visit from the plumber.
Posted on Jun 09, 2009
  • 464 Answers
SOURCE: my washing machine is not spinning and my clothes
You need to get someone to check the speed control board on your machine.
Posted on Dec 09, 2009
heatman101
  • 43501 Answers
SOURCE: E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
E20 errorcode
Sorry but with no Make we can no assist .try Google Make/model/error code
Sep 08, 2015 | Dryers
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
Mar 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
Wont spin
check drain pump for obstruction, (access from rear panel) pull hose boot from tub and ck basket in hose. read tech sheet for code definition while your there. have plenty of towels and wet vac ready
Mar 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
E20 Error Code
Greetings jeanne1568,
Other consumers have reported this error message and found it relates to your "Coin trap assembly" being blocked, therefore not allowing all the water to pump out. The suggestion out there is to remove the front access panel, and remove the clamp that connects this trap assembly to the pump and clean it out.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error codes
I suggest you snake out the drain into which the machine waste hose goes, the standpipe that is. The drain could be blocked somewhere causing pressure problems which is conveyed to the machine. Be sure to replace the machine exit hose at about 3 feet from ground level, and dont shove it too much into the standpipe. Do not block up the point where the machine hose goes into the standpipe, it shouldn't be air tight.
Dec 28, 2007 | Frigidaire FTF530FS Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
278 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
