Question about Canon HV20 HDV Digital Camcorder
Connect Canon DV20 to Computer
When I connect the HV20 to the computer by firewire, the computer does not detect it. I tried it on a computer with Vista, as well as a computer with XP.
Both computers have Pinnacle Studio 11 Ultimate.
Any suggestions????
  • 1 more comment
  • Happyski May 12, 2008
    USB cable only works with memory card.
    Does not connect to camera.
    After it happend the first time, I purchased a new cable at best buy.
    The same thing happend.
    Whe I connected the camera the very first time, the computers detected it fine.
    this is now the second time I tried to transfer content to the computer, and now it does not detect the camera anymore.
  • Happyski May 13, 2008
    I tried all past recommendations and it still does not work.
    Genius:
  • 3,422 Answers
Do you have another PC or laptop then pleasetry to connect it on the other laptop and see if you face the same problem.If you get the same problem again then the fault is with your camera and you will have to get it repaired or replaced if it is still under warranty.
If you don't face the problem then the problem is with your first PC/laptop which you tried to connect.Do one thing take a backup of your Pc/laptop and then do a system restore.
Doing a system restore it will restore your Pc/laptop to a previuis time when it worked fine and also make sure you don't connect the cam into it..
System restore:
START>ALL PROGRAMS>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE
Another few points:
Make sure your using the right vista drivers for the cam on your Pc/laptop.Also try reinstalling them again..
Goodluck,
Please don't forget to rate the solution
Posted on May 13, 2008
  • 796 Answers
Try reinstalling the driver for the camera...
and vista doesnt support most of the new cameras drivers..
also try with other compatible camera drivers....
    President:
  • 2,712 Answers
Try using a different connector like the USB cable..
Posted on May 12, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 12, 2008
    1. Apparently, Service Pack SP2 can interfere with Firewire, & Microsoft issued a patch to solve it.
    It's at
    http://www.microsoft.com/downloads/detai...
    (You must be Administrator or Administrator-equivalent to install.
    Or search Microsoft Download Centre for Update for Windows XP (KB885222)
    2. You could also just try deleting the Firewire driver in
    Device Manager, reboot and Windoze will replace the driver via
    plug-and-play. This has reportedly worked for some folks.
  • Swilin Sampson
  • Swilin Sampson
    THIS article also prove useful..
    Master:
  • 351 Answers
Dear,
Please check the firewire cable, maybe the cable is faulty.
regards
How to connect canon gl-2 camcorder to computer
Are you using the proper Firewire cable to connect? Also, the GL2 has had issue with the Firewire port going bad. Try a different cable and see if that helps. It can't be a USB-Firewire cable either.
Sep 07, 2014 | Canon GL2 Mini DV Digital Camcorder
I have canon power shot SD11001S. when i connect this to mac laptop it dont detect. but when i connect in another laptop having windowsXP then it detect. how to solve this problem??
Try NOT connecting your camera to your Mac. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Dec 17, 2010 | Canon PowerShot SD1100 IS Digital Camera
Hello, I recently shot a student film on a Canon HV20 HDV Camcorder, Problem is my school doesn't have an HD deck to allow log and capture. I have final cut 6 and still can't get the setting right to...
This camera works fine with FCP 6. I use it all the time. You need to use the Easy Setup for Firewire basic HDV 1080/60i (or whatever sounds like that). The camera should be connected from it's small connector FIREWIRE port(under back panel cover -- USB port will not work for this use) to either a Firewire 400 or Firewire 800 port (auto-switches to 400Mbps if the device doesn't support 800) on the computer. Cables are available with a variety of connectors for this for under $20 ea (it's digital -- i.e. don't overspend on cables unless you have an actual problem!).
Mar 13, 2010 | Canon HV20 HDV Digital Camcorder
I can't upload video from my Canon GL1
first off make sure you are positively connected to computer via usb. then make sure your drivers are updated. then see if it connects. also note that your camera screen may say "would you like to connect to usb port?" make sure if that does appear that you hit yes. best of luck!
Feb 17, 2010 | Canon GL1 Mini DV Digital Camcorder
Arghhhh! Why isn't my HV20 canon camera detected through Vista???
firewall or virus software should be turned off when installing uninstall and try again. also make sure no other usb are plugged in or other programs open or running good luck
Jun 17, 2009 | Canon HV20 HDV Digital Camcorder
Connecting the Canon FS 100 to my iMac
jhobby2000 buy a usb 2.0 specially for SD or SDHC chip
Dec 31, 2008 | Canon FS100 Digital Camera
I'm trying to connect my canon hv 20 to my macbook pro, and the computer won't detect the camera.
Connect via USB to see contents of the miniSD card. Connect via Firewire to do anything with recorded video/audio. USB setting may require further fooling around with camera settings to be visible on some computers, since the miniSD card should mount, just like a flash drive. I have one of these camcorders and this all works just fine.
Dec 23, 2008 | Canon HV20 HDV Digital Camcorder
How do I capture vidio to my conputer
You will need a capture card and a video editing program on your Windows machine, and what is known as a firewire input. Macs from the G3 upward have a firewire input built in. Macs come with I-Video program which offers log and capture and editing capability. Connect one end of he firewire cord to the camera computer output and the other to the computer. Select the log and capture option in the software and transfer video. You will need lots of hard drive space to store your video, about 10 gigs per hour. You will also need a way to burn your video to DVD if you wish to save it and view it. Some people just upload their video to YouTube, which will only accept video of nine minutes in length or less. While it may seem simple, there are a lot of techniques you will need to learn to capture, edit and output video. You will need to experiment a lo before you learn all the tricks and variations in this process/.
Dec 01, 2008 | Canon HV20 HDV Digital Camcorder
My canon HV20 do not connect with my dell studio 15 laptop
do yuo have an external hard drive connected...that will interfere with the connection sometimes, hdv/dv should appear in solid whilte letters unders stereo1 in the lcd on the camcorder screen, and what version of vista is it and is the firewire cable plugging directly into the pc...if it doesnt work in one port try another in different location on it.
Nov 25, 2008 | Canon VIXIA HF10 HDV Camcorder
Cant detect camera on dv video recording transfers.
Hi, I hope the camera you are talking about is ZR200 Mini DV.
As per its specifications. It has a firewire/DV port.
Therefore, follow these steps. I assume you are using this cable. http://cdn.overstock.com/images/products/L10726964.jpg
I am not sure how you used the firewire cable before.
So, try this. Connect one end of the cable to computer and other to the camera. Switch on the camera and keep it in play/ edit mode (not in shooting mode).
When you connect the other end to the computer,  There should be a popup asking you what to do.
If there is no popup,  Open Windows Movie maker and import video from device. You should see the camera in it.
Hope it works.
Sep 24, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon HV20 HDV Digital Camcorder Logo
517 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
