Question about HP Officejet 5610 All-In-One InkJet Printer
HELP! My fax fails a lot. I get the error Error 232* What is wrong? It works sometimes but not others. I really really need this fax for our charity work. What is error 232????? Please help me.
    Sergeant:
  • 223 Answers
To help with your error, what you will need to do is go in to your menu on your printer and under fax set up and all faxes you need to turn off ecm and v.34
Posted on Sep 02, 2010
  • 2 more comments
  • Trevor Groves
    Trevor Groves Sep 02, 2010
    Are you using the fax on the same line as your ADSL or internet feed. Often noisy lines will also cause such problems, If so try a line filter, I have also sometimes had to use two of them to get the ADSL line clean enough to fax properly. connect a phone to your Fax machine. dial and talk to a friend, listen carefully for noise. Apply the filter and try again. You may have some in the box that came with your internet modem if this is the case. Quite common.
  • Trevor Groves
    also be sure you trying to fax on a conventional analog phone line as with many new Voip style IP lines there is a whole bunch of issues that would need to be addressed for proper faxing.
    If you can. Try plugging that fax machine into another fax line (to rule out internet feed noise from ADSL or a poor quality line, bot of which has happened in our offices.). This would eliminate having to locate a ADSL line filter in my previous post. I hope this better suits your question, and provides you with a solution.
  • Trevor Groves
    please correct your answer rating or add some more comments so i can help you further.
    Thanks Gurvy
  • Trevor Groves
    Trevor Groves Sep 03, 2010
    having a thums down rating means to me this did not solve your problem, did any of my above comments help you? I will keep checking/ helping you in this thead until we get your trouble resolved. please make additional comment or re-adjust your rating. Thankyou Gurvy
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
What is the meaning of eror 232*
Error Code: 232
  • A communication failure occurred between the two machines.
  • The user at the remote machine might have pressed the Stop key.
  • The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
  • The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Solutions
  • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM .
  • Set the host machine to receive at a slower transmission speed.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems.
Nov 04, 2009 | HP OfficeJet J4580 All-In-One Laser...
Fax comm error 232 problem
Hello sir ; Why don't try to replace a phone cable or check the wall jack.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
C7280 fax error code 232
They might be trying to send from a DSL phone line.
Aug 18, 2009 | Office Equipment & Supplies
HP office jet 6210 All - in- one /error message 232
Please consult this page for links to fax error codes for your printer.
In particular, Error 232 yields this info:
Error Code: 232, 233, 234, 235 ECM, 236 ECM, 237
Definitions
Solutions
If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
You can also access the home support page for your printer here., in case you should have further troubles.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | HP PSC 2410 All-In-One InkJet Printer
We have an HP L7780 and have problems rec. faxes - error 232
Hate to say it, but it means "Don't buy HP printers". You'll be a whole lot happier with Canon or Epson. I had no end of trouble with more than HP all-in-one. They just get flaky after awhile, and the software (particularly scanning) is terrible.
Apr 18, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Jul 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
373 people viewed this question
Seeker5211
Seeker5211
