Question about Stanley Bostitch STB-MIIIFS Flooring Stapler
I HAVE A BOSTITCH NARROW CROWN AIR STAPLER AND THE STAPLES ARE NOT GOING FOREWARD FOR THE ROD TO DRIVE THEM IN. IS THERE SUPPOSED TO BE A SPRING BEHIND THE STAPLES TO MOVE THEM FOREWARD. PLUNGER COMES DOWN BUT STAPLES DO NOT COME OUT.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
John must work for Stanley or B&D Dewalt...
There is a constant force spring in most if not all magazines
Posted on Aug 09, 2012
    President:
  • Stanley Master
  • 1,383 Answers
There is a spring to push the staples into place. Bostitch was purchased by Dewalt and moved their parts lists to the web address below. Enter your model number and order the parts needed. Good luck with your future projects.
http://servicenet.bostitch.com/
Posted on Oct 17, 2011
The staples do not go far enough into the sdlide chamber to allow the hammer to strike the staple. The staples do not show in the openning when it is loaded. What am I doing wrong? I have a model D51420 18...
I believe on that model you have to release the magazine latch, pull the lower half all the way back, load the staples into the upper half of the magazine, then close and latch the lower half. The staple pusher and spring are located in the lower half so the staples need to be in front of that for them to be properly pushed into the nose. Also make sure you are running the correct staple. There are 1/4" and 3/16" narrow crown staples out there and they don't interchange. The staples should slide freely in the magazine when they are loaded.
Jul 17, 2011 | Dewalt Air Tools & Compressors
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
I have an older Fasco stapler, it is orange in color. S3G 16 is number on it. The part that pushes out the staple has a piece of staple stuck in it. How can I get this out?
Some models have small screws on the face plate that can be unscrewed to release pressure or a spring clip to release. You can also push the plunger back into stapler with a thin narrow srewdriver, the staple may fall out.
Nov 30, 2010 | Fasco 9 Narrow Crown Pneumatic Staple Gun
Can not drive nails. Loud air hiss at top on tool
you have an air leak and you have to fix your stapler nailer hope its not cracked but just a seal
Sep 24, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
My brad nailer shoots staples without any problem but it jams on the second brad after being freed up from the previous jam. How to I rectify this problem. It is a fairly new stapler/nailer and has done...
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
Mar 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
The gun will fire staples, nails do not set.
The business end should look like this:
Mar 07, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
Jan 17, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
B310HDS Stanley Bostitch stapler rod to lock stapes has plastic t
I have the same problem and have found no answers from Stanley Bostitch customer service. They redirect to a telephone number that does not answer.
Solution: Don't buy Stanley Bostitch.
Jun 03, 2009 | Stanley Bostitch 00540: 00540 AntiJam ?...
Stanley Bostitch STB-MIIIFS Flooring Stapler Logo
294 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
JOHN LAPIER
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
