Question about Epson Stylus RX500 All-In-One InkJet Printer
I have an epson stylus photo RX500. When I turn it on it imidiately gives me an error message. saying to see documantation.. My compouter says that parts inside your computer are at the end of their service life. I called Epson and they tell me that the foam at the end of the carriage is probably saturated. I cannot move the carriage over to get at it. Can you tell me how to do that? thank you
    President:
  • 3,278 Answers
Hello.
The error you are getting is the protection counter error.
The amount of ink discharged by the printer has reached the maximum value allowed and the printer requires to be reset.
To clear the error, follow the instructions that you find here:
http://myprinter.altervista.org/simplefaq/mysimplefaq.html#counter
Once the error has been cleared, the printer should be Ok.
However to avoid further problems, you check and clean the waste ink pads where discharged ink is stored.
To reach the pads you have to disassemble your printer. You can find an exploded diagram here:
http://www.compassmicro.com/parts.cfm
Pads to clean (or replace, CompassMicro should sell them) are parts #553 to #556, #540 and #541 listed at page #4.
Please note that CompassMicro is just a suggestion. I have not personally used this site.
Hope this helps.
Posted on Sep 02, 2010
Epson Stylus PHOTO RX500 - PRINTER ERROR message
keep pressing the button, until it stops where you want.
good luck
Mar 21, 2010 | Epson Stylus Photo RX500 Printer
Epson Stylus Photo RX500. I was cleaning print head when I got "printer error" message. The load eject light is on. I've unplugged printer, turned it on and off. no luck. solutions?
Press all these buttons:
Power+Load/Eject+Stop+B&W+Color
When printer turns ON, "Init eeprom" appears
Release and Press the Color button.
Jan 06, 2010 | Epson Stylus Photo RX500 Printer
My RX500 is recognized in the device manager and says that it is working properly. When I click print on my computer...the printer cache SAYS that it's printing...but the printer doesn't respond to the...
TROUBLE SHOOTING GUIDE
Question History
Step 1 WHICH MODEL ARE YOU USING? Stylus Photo RX500 Step 2 What were you doing when the problem occurred? Printing Step 3 What happened when you tried to print? No response from the device Step 4 How are you printing? From the computer Step 5 Are any of the Mode lights on? Yes Step 6 Which message is displayed on your device's control panel? None of the above Step 7 WHAT IS THE DEVICE'S STATUS? Ready Step 8 Are you able to print your device's nozzle check using the buttons on its control panel? Yes Step 9 Do you see an error message on your computer screen? No Step 10 Which operating system are you using? Windows XP Step 11 Make sure the correct printer and port are selected in the software. Does that fix the problem? No Step 12 Reconnect or reconfigure your cabling. Does that fix the problem? No
Says for you to Contact Epson
1. Based on the information you provided, here is what you need now.
http://er.epson.com:8001/start
Based on the information you provided, here is what you need now. Please contact Epson to resolve this problem with a technical support representative
(562) 276-4382
6 A.M. to 6 P.M., Monday-Friday
(Pacific Time)
If you find this helpful, pls rate me.
Thanks and Good Luck......
Dec 27, 2009 | Epson Stylus Photo RX500 Printer
I just re inked my Epson styles Photo RX500. All the ink levels read low except Black. I removed all the cartridges and repeated the process.and, all the ink levels read low except black.I get a ERROR...
what is the error message? try to turn off and on your rx500. note for an epson printer it requires all inks inorder for it to function or else it will be on an off line state
Sep 14, 2009 | Epson Stylus Photo RX500 Printer
Scanner error
Press the On button to turn off the Stylus Photo RX500. Unlock the transportation lock. Make sure that all packaging materials have been removed. Turn on your Stylus Photo RX500 again. If the error message still appears, call Epson so they can replace your printer.
Goodluck.
sherlyn C.
May 23, 2009 | Epson Stylus Photo RX500 Printer
Message: Error paper jam. There is no paper jam.
Yes there is some micro piece of paper is under a sensor somewhere Get serious and pull it apart, what have you got to loose! Inkypete
Apr 20, 2009 | Epson Stylus Photo RX500 Printer
RX500 won't copy
what operating system are you using and what is the specific error message when you attempt to uninstall the driver?
Apr 01, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson printer scanner rx500
here is your solution click on the following link
http://printers.free-driver-download.com/Epson/2568/Epson-Stylus-Photo-RX500-Printer-Driver-v5.4bA-Win2000-XP.html
Dec 08, 2007 | Epson Stylus RX500 All-In-One InkJet...
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
95 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
