Question about Poulan Garden
Trying to replace starter rope on poulan pro ppbe weedeater. having trouble getting to pulley. what screws do I need to remove to get to pulley without taking everything apart?
  • 1 more comment
  • double4205 Sep 02, 2010
    ppb 150e
    I need model specific answer. this model requires more. ppb150e poulan pro multi attachment weedeater/edger.
  • double4205 Sep 03, 2010
    the cord hole is on top and the actual pulley is in the middle of the weedeater. I cannot take the cover off with two screws and replace rope
  • 857 Answers
Follow these steps:
•1
Loosen and remove the starter cover's screws from the saw with the screwdriver. Pull off the starter cover.
•2
Feed the starter cord out of the pulley two turns. Use the screwdriver to pop open the center clip in the pulley that holds the cord in place. This clip often looks like a cube.
•3
Take the cord off the pulley through the hole where the clip was holding it down.
•4
Feed the entire new starter cord into the same hole. Push the clip back down in place over the new cord.
•5
Use the screwdriver to pop open the plastic starter handle on the end of the old cord. Take out the metal insert and untie the old cord from it. Throw away the old cord.
•6
Feed the new cord into the starter cover, plastic handle and metal insert. Tie an overhand knot in the end of the cord. Do not tighten it yet.
•7
Push the cord and metal insert back into the plastic handle, making sure the knot doesn't tighten. Pull the knot tight after they're inside the plastic handle.
•8
Turn the pulley to wind the cord up. Tension the recoil spring by pulling the cord out two full turns and feeding it back into the pulley.
•9
Set the starter cover back in place, and use the screwdriver to tighten the screws that hold the cover in place.
Posted on Sep 03, 2010
    Genius:
  • 1,456 Answers
Hello
Use a screwdriver to remove the starter cover screws. The starter cover on most Poulan models is at the back end of the engine, near the muffler. Take off the starter cover and the starter cord should come off with it, because it's attached to the starter cover.
Pull out the entire length of starter cord from the pulley. Locate the tab in the pulley's center that locks this cord in place. Pop this up with your finger or the screwdriver. Pull the cord off of the pulley.
Use the screwdriver to open up the plastic starter handle off of the old cord. Untie the rope from the metal insert that's inside the handle. Discard the old cord.
Insert the new cord into the same center access hole that you pulled the old cord out of. Pull it all the way through and lock the center tab by pushing it down into place over the new cord.
Thread the new cord through the metal insert and the plastic handle. Tie a regular, overhand knot in the end, but keep the knot loose. Push the knot inside the handle, tighten it against the metal insert and close the handle over the knot and metal insert.
Wind the cord around the pulley all the way. Hold the cover in one hand and pull out the cord two full pulley rotations to set the tension on the recoil spring. Repeat if necessary to get the proper tension on the cord. Screw the starter cover back into place over the engine and thats it!!
Great day!!
Posted on Sep 02, 2010
My wiper sniper pull cord is broken, how do u change the pull cord?
Hi vanzedo, I will try to help you out. Because you don't specify the brand and model I will try to give you the Weed Eater brand that is manufactured by Poulan because it is the best known in my area and I hope it is well known in your area, but it is pretty well the same procedure for other brands.
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eye wear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation. Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to you even if a little bit. Regards and good luck. Denis.
Apr 02, 2011 | Garden
How to change the pull cord?
Hi b calm,
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eyewear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation . Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to even if a little bit. Regards and good luck.
Mar 07, 2011 | Ryobi Garden
How do i get the spring back into the recoil
I think he's trying to replace the recoil starter spring. He's having trouble getting the spring and pully and rope back into the housing. I'm trying to do the same thing with an old Green Machine weedeater and would appreciate any help.
May 10, 2010 | Craftsman 25cc Gas Line Trimmer
How do I replace the pull rope on the TE 475 weedeater? I went to start it today and pulled on the rope and it all came out.
How do I replace my pull cord on my weed eater TE 475? I have the parts diagram, I need to know where the cord attaches and what the steps are to rewind the pulley and attach the cord.
Oct 19, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Need to change pull rope on Poulan Pro Weedeater
sounds like you are trying to remove the drum assembly; try a torx driver or a phillips screwdriver. There is a srew that hold that drum on and the bolt is in that black hole.
Sep 29, 2009 | Poulan Garden
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Weedeater pull cord will not return to original position
Hello mart656:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog Poulan/Weed Eater.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Apr 27, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
HOW TO TAKE THE MAGNITO OFF OF A 306A POULAN CHAINSAW
I can't find your model number at Poulanpro.com but in all the chainsaws that I have worked on the starter rope comes in the cover which is held on by usually 4 or so screws. I suggest that you go to the site I listed and look at the 42 CC engine (they have a parts manual for it) before removing anything else. Let me know if I can help further.
Mar 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Attaching starter rope to pulley
The factory method is to bring the pull cord through the hole on the outside of the pulley, wrap clockwise once around the cogged part of the pulley, then over the pull cord and a clockwise wrap under the screw with the searated washer.
Dec 25, 2008 | Poulan Featherlite Gas Blower, with Low...
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
643 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
