Question about Mackie SWA1501 Subwoofer
The mains input fuse (4amp) and a (1amp) fuse on the main power out board were blown. Replaced fuses and switched on, blown again, disconnected output from transformer to main board (4amp) fuse did not blow fault appears to be on main power out board. Further investigation showed R1 (4.7K) on circuit board had becomed detatched and main power board and output transistors checked out dead short in all directions. What is the best course of action, replace transistors or complete board swap. Where is the best place to buy one or the other. Thanks for your help.
  • Mackie Master
  • 5,158 Answers
The cheapest option is to replace the transistors (a quick check on google will tell you how much they are). If they are common transistors you will be able to find them and get them quicker then searching for a board that could be no longer being made.
Posted on Sep 02, 2010
Samsung PN51d7000ffzxa Plasma Screen does not power on, Power light blinks RED
if the power supply is a new one and you follow the steps described,ther`s no doubt,the main board is bad. good luck! from Mexico City.
Jan 24, 2015 | Samsung Televison & Video
No power fuse blown replaced fuse new fuse blown
It shows that there is shorting in the further circuit,check MOV (metal oxide varistor) used for protection in the mains supply,MOV is mounted parallel to the main input supply,if o.k check further bridge rectifier and finally switching device used for SMPS power supply either transistor or STR by replacing the same.
Feb 04, 2011 | Emerson TS1997 19" TV
I have the red power light, but when i turn it on, it completely shuts off, red light and all. Then i have to unplug it from the back to get the red light back
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
NOTE.... you have to open the console to do this ...
I hope this help in solving the problem.....
Nov 10, 2010 | Nintendo Wii Console
MY PS3 WONT TURN BACK ON
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
I have an LG WM2277HW washing machine. My wife went in this morning to do some laundry and the thing is completely dead. No lights or signs of life. I checked the house circuit and the power to the...
Make sure the noise filter connectors are clean and connected properly. Get yourself a multimeter and check the voltage both on the load side and line side of the noise filter. It should read the same at 120VAC. The noise filter is the board before the main board. Replace it if the voltages on its load and line side are not the same.
The main board is not serviceable and must be replaced if faulty. It has a fuse and if it is blown, the main board is probably faulty. Look at the two brown capacitors on the top left of the main board. Next to it is a heat sink and to its right is a white "fuse-like" component with silver ends. That is the main board fuse. If it is blown, disconnect all the connectors from the main board except the one connecting it to the noise filter. Jump a single thin strand of wire in place of the fuse and apply power to the machine. Check if the power LED indicator on the main board lights up. If it does not, the main board is dead, replace it.
Please do not hesitate to update me about your findings above for further guidance if necessary.
Jan 12, 2010 | LG WM-2277HW Front Load Washer
Model 805 Simpson top loader. No Power, lights, nothing at all. Have checked power point with another appliance and is ok, is there an inbuilt fuse in the machine, or could the on off switch be...
If its the model i'm thinking of, there is a fuse located on electronic board. disconnect power. acess by removing 3 screws along top rear, top panel comes off. locate fuse-if faulty, fuse should be replaced with a 4amp slow blow fuse.
Aug 08, 2009 | Washing Machines
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Bush pdp42tv006 4amp fuse blown . not the main fuse.checked for shorts .any help? thanks
pls check the main power supply<regulator> hang the loads going to secondary supply,
Apr 29, 2008 | Televison & Video
Blown fuse 1.25amp Board pos. 1452
The main fuse should be a 4 amp fuse not a 1.25 amp.
Jan 26, 2007 | Philips 32PT6441/37 32" TV
Mackie SWA1501 Subwoofer Logo
796 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
