Question about KEF Audio PSW 2150 Speaker
I need help with the settings for my KEF PSW-2150 subwoofer and I would also like to find a manual
Manual posted at the following link:
http://lug.demon.co.uk/kef/psw2150_user_manual.pdf
Posted on Dec 05, 2010
I have a Yamaha HTR 3063 reciever and I just got a PSW 2000 Kef sub and I can't get the sub to WORK NO MATTER WHAT I DO PLEASE HELP
That is a potentially great combination. I have a Yamaha receiver but I am not familiar enough with Kef to know but is it possible your receiver expects to be connected to a powered sub. Are you sure the Kef works by itself? Have you checked to see whether the receiver subwoofer output works with another speaker? Could receiver mode selection be a factor? My Yamaha switches various functions on and off depending upon your preference.
For what it's worth, the troubleshooting section of my Yamaha manual says a subwoofer no sound problem can be caused by selecting MAIN LFE/BASS OUT on the SET MENU when Dolby or DTS material is being played or selecting SWFR when a 2-channel source is being played. Something has to work!
Sep 10, 2012 | Audio Players & Recorders
My Kef Subwoofer model PSW 1000.2 is not producing any output, before all this I got a constant noise from it and now there's no noise at all even though all the settings on my amplifier (Sony...
First of all you need the service manual for the same. That i have with me. If you can sent your email id through fixya will sent the same to you. Just read the service manual and watch the circuit diagrams. There are different voltage measurement points.You have to check the power supply first. It will be very easy to both of us if you also have the service manual. if so i can assist you in the Wright way. It is not possible to set the service manual through fixya because its a large pdf file.
ok
Jul 16, 2011 | KEF Audio PSW 1000 Subwoofer
My KEF (PSW 2150) ruffer speaker buzzes even with no input connection?
Your amplifier is bad. I sent mine to KEF in NY and they fixed it for $100 US.
Dec 08, 2010 | KEF Audio PSW 2150 Speaker
Hello ! I'm not sure how to connect my kef psw 2500 sub to my yamaha amp. I've got a subwoofer out on my amp but there's 4 inputs on the sub and I don't no which one to use ! Please help as getting...
Just for clarity, I need to explain what the four inputs are on the KEF subwoofer. There is a left and right RCA input which is the input signal to the subwoofer and there is a left and right RCA output which is the High Pass output from the subwoofer.
On the back of the Yamaha receiver, you said you have a subwoofer output. This output is most likely the mono subwoofer part of the home theater system and can be used if you like. The left right signal input into the KEF is summed into mono so if you only connect one channel you will basically reduce the signal level by 1/2 (-3dB) but it will work fine.
Alternatively, if your Yamaha receiver has monitor out and monitor in, you can run the monitor output signals to the subwoofer and you can then run the high pass outputs from the subwoofer back to the monitor in. This will give you the subwoofer and provide a smoother signal matching with your audio system.
It is not always easy to connect the subwoofer up to an integrated receiver/home cinema system using the high pass channels of the subwoofer as you don't always have access to the analog output and input of the front channels. In this case, just use the Subwoofer output or just the monitor out only.
I hope this solution is helpful.
Dec 03, 2010 | KEF Audio PSW 2500 Subwoofer
How can you bypass a subwoofer amp
If it came actively powered and permanently connected but you do not want to use the supplied amplifier, then you need to disassemble the subwoofer cabinet and disconnect the amplifier from the driver.
Oct 07, 2010 | KEF Audio PSW 1000 Subwoofer
Im having trouble with connections from kef psw 1000 sub to onkyo tx sr506 amp. sub is making a bit of a humming noise but not getting any proper sound through. dont know what im doing wrong. can anyone...
Have you got the sub defined to the Onkyo correctly? Try conencting the sub's input to one of the Tape Out connectors and play some FM through it. That will prove if the sub is alive. The nwe can troubleshoot the correct failing device.
May 03, 2010 | KEF Audio PSW 1000 Subwoofer
I just bought a KEF PSW2500 subwoofer and am trying to connect it to a Yamaha v663 receiver. However, I went from a subwoofer pre-out 1 to the right line in on the sub. I don't hear any sounds from the...
HI,go into the yam setup menu and make sure you have the sub turned on and cross over set to about 80hrtz if this suits your speakers,set sub level to about -5 on amp and say half way on the sub,this should work if not pull out sub cable at amp and touch the end,you should get a hum,if not you may have no power,faulty cable or sub.
PS>make sure you are pluged into the sub PRE OUT and NOT the six channel in.
Hope this helps.
CABLE GUY.
Apr 19, 2009 | KEF Audio PSW 2500 Subwoofer
I'm looking for a KEF PSW 3000 manual download
Try this website for KEF. They have all the manual downloads and I fixed my circuit board from calling them and asking for advice for free. The number or email to get a reply is here. Happy Holidays.
Mike
http://www2.kef.com/us/support/warranty
Dec 26, 2008 | KEF Audio PSW 3000 Subwoofer
Open Questions:
See all KEF Audio PSW 2150 Speaker Questions
KEF Audio PSW 2150 Speaker Logo
432 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
shaqsatin
Level 1 Expert
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
