Question about Toshiba 72MX195 72" HDTV
Just replaced bulb on toshiba 72mx195 it wont turn on and the two front lights r flashing i can hear it running on in the machine but no picture
techman
  • 3130 Answers
SOURCE: Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Posted on Nov 07, 2007
djnick989
  • 1067 Answers
SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
Posted on Jan 29, 2008
ctf1800
  • 4402 Answers
SOURCE: toshiba 52Hmx94
How many times does it blink?
I replaced the ballast in my 62HM84 and it fixed it. The problem was TV would not turn On, Red light solid green light blinked 9 times then TV would try to restart. At first I thought it might of been the bulb, so I replaced it, same results. Next I replaced the ballast which is pretty easy, just take pictures before you remove the light engine so you can go back to the picture to verify the connections when reinstalling.
Posted on Feb 11, 2008
texasdan
  • 60 Answers
SOURCE: Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Posted on Sep 28, 2008
  • 4 Answers
SOURCE: Toshiba HMX94 DLP I replaced the bulb after it
The problem most likely is with either the lamp ballast or the light engine. The lamp ballast is the part that provides voltage to the lamp unit and is usually not all that expensive a part. The repair cost from a service shop can be about $300 or more. If you are handy, you can replace it yourself. Check out www.thepartstore.com for the ballast.
Posted on Jun 23, 2009
72MX195 won't turn on blinks 16 times
The power supply may have failed.
Oct 30, 2013 | Toshiba 72MX195 72" HDTV
My left turn signals don't work.you can hear the clicker working normal and the courning lite come on. If you leave the signal switch on the turn lite will flash once in a while and also the lite on...
You most likely have a bad bulb, if the front bulb goes the rear wont work and vise versa both bulbs must be good to complete the cirrcut. Even though you have no lights you should still hear the flasher relay. Bulbs are cheap just replace both and you'll be good to go. Good luck
Aug 18, 2011 | 2001 Buick Park Avenue
What does it mean when the tv shuts off and the blue light flashes followed by the yellow
Ouch. Sounds weird. Do you mean the whole screen turns blue, then the whole screen turns yellow?
Try pulling the power cord from the wall a cycling the unit back on again.
Aug 15, 2010 | Toshiba 72MX195 72" HDTV
Wont turn on red light in front flashing
You've got to replace the bulb. I've had my KF-50WE610 for four years. Mine just went out again too. This is the third bulb in four years. The bulbs are expensive too - $100 -$200 each!
Dec 03, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba projection TV. Bulbs wont come on
The deflection board in failing, eventually it will not come on at all, disconnecting power is only reseting the HV shutdown protection circuit which is the reason your set if failing. Have a technician replace the Horizonal Output Transistor and the flyback transformer.
Please comment if you need futher assitance.
Delhielectronics@live.com
Sep 29, 2009 | Toshiba 55H70 55" Rear Projection...
Front driver side turn signal light doesn't flash.replaced bulb,replaced socket,all other lights work on emergency flasher,except front driver side.rear driver side turn signal light works,but flashes...
replace flasher......usually located in fuse block area...listen in this area....select passenger side ...then select driver side...you can hear flasher clicking...you have seperate flashers for each...FLASHERS are small cubes plugged into fuse block....probable bad driverside flasher
May 09, 2009 | 1998 Buick Century
Toshiba 52Hmx94
Dec 25, 2007 | Toshiba 52HM95 52" HDTV Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 72MX195 72" HDTV Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
