Question about Vizio Televison & Video
I have 55" Vizio lcd tv (E550VL). The "WIDE" menu gives me the option to change to screen to WIDE, FULL, ZOOM or STRETCH. When I click one of these, nothing happens. Is there something else I should be doing?
  • 10,594 Answers
Picture aspect ratio wont work on HD channels/ signal as HD signal over rides on these settings and has own unique picture aspect ration.
Try with dvd playback picture, you would be able to adjust screen aspect ratio to Wide, Full, Zoom etc.
Thanks.
Posted on Sep 02, 2010
What causes screen to go black
you have change main board cost 145 to 165 ? had same problem had repair came to the house tv shot he said!!!! i look further into and talk to other people it (main board) . this is for e550vl tv parts # there are couple of them 3655 0162 0150, 3655 0072 0150, 3655 0112 0150 and my tv took 3655 0152 0150 and take me 25min put back together after take tv back off and confirm part # on main board.
Dec 11, 2013 | Vizio E550VL 55 in. LCD HDTV
White dots on screen
Most likely T-Con PCB. Part Number varies (See Below)
http://www.shopjimmy.com/tvs/tv-t-con-boards?restrictBy[known+models]=VIZIO+E550VL
Nov 25, 2013 | Vizio E550VL 55 in. LCD HDTV
VIZIO E550VL
Replace the main board the eprom has an issue. You can get the replacement main board from www.tvcircuitboards.com
Dec 14, 2012 | Vizio E550VL 55 in. LCD HDTV
Just recently my sharp aquos lc 40 e is stuck in stretch of wide screen and the heads or top of things are being cut off. When i go to view mode it only gives me 4 options wide, stretch dot to dot or zoom...
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
Aug 29, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have a vizio 55 in. e550vl the hdmi ports quit working when lightning hit a tree by the house i think maybe a surge came through the satellite if i was to replace the main board would that fix it i...
I am having the same issue with our Vizio E550VL TV. Does your TV show No Signal on the screen? I was able to get regular AV to work with the Yellow, Red, and White cable to work but none of the HDMI ports would not work. If it does not power on at all it may be the power supply. I had to order the main board to get it to work correctly. Vizparts.com is where you can order it from.
Aug 10, 2011 | Vizio E550VL 55 in. LCD HDTV
Television scrfeen will not go back to normal, seems to be stuck on either a wide setting or stretch, have tried to go through controls and fix manually but it doesnt work
Hi, Look in TV menu for settings of screen. ( aspect setting) 4:3 , wide screen mode , Normal (full), Zoom mode. You want Normal (full) mode. Good luck.
Jul 27, 2011 | Vizio VW32L 32 in. LCD HDTV
Picture not filling screen on vizio 37" tv
Hi my name is Eric,
I hope I can help you with your issue ,
There are a few buttons to adjust the picture size on different make TVs and even on the Cable/Satellite remotes .
1.Format
2.Aspect
3.Size
4.Zoom
5.Wide
6.#
First look on the TV remote, set it to Full ,Fill or Just.
Then on the Box remote stretch is usually best.
On the box remote set the output resolution to 1080i only
And use 16x9 when if offers a choice.
Cable remotes use the # key as a zoom button.
Due to the fact there are 16 size/Formats available (3 or 4 being transmitted now). you may have to hit the zoom/stretch button on some HD channels.
But with these settings the picture will mostly stay full and help you avoid image burn from the edges being not on the edge.
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Vizio L37 Television
Picture doesn't fit screen
If you haven't tried to change the format yet, try that first. Most of these tv's have a wide range of options from full to wide to split etc. Stretch would probably work in most hd formats.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Cant see full picture w/ Vizio 32in HDTV
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
Apr 16, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
240 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
