Question about Apple iPhone Smartphone
I had a prompt to update to 4.0.2...I hit ok and now I have lost everything off of my Iphone...Is there anyway to reverse this and to get my information back?
    Problem Solver:
  • 5 Answers
If you've backed up your iphone but i doubt you have because it shouldn't have deleted your stuff if you had backed it up on itunes. it takes along time but you should do it. I think you accidently pressed no for the backing up part
Posted on Sep 02, 2010
Testimonial: "Yes, you were right...I did hit the no...I did sync the iphone with the computer, I got everything back, but I didn't get my icons back."
Just upgraded iPad 3 to iOS 8.1.1. Now everything freezes up. iPad won't even turn off at all. Is there anyway to reverse an update?
My iPhone upgraded fine. Try a hard reboot - hold power and home together until it goes off, keep holding until you see Apple logo then release and let it finish booting. If that doesn't work, may need to force a reinstall of the update via iTunes.
Nov 20, 2014 | Apple iPad 64 GB 3G Tablet PC
What are ways for iphone data recovery
You must have a backup in the pc if you choose to use itunes. Check that. This has to be restored on the original or a newer iphone.
Dec 03, 2013 | Apple iPhone 3G
Camera standby
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPhone 4 will erase everything on it, so make sure everything on the iPhone 4 is stored elsewhere prior to restoring. To restore, connect your iPhone 4 to a computer with iTunes installed. Click "Restore" on the iPhone 4 summary page (click on your iPhone icon on the left menu to find this page). Follow the directions to restore. If your iPhone 4 displays the text "Please wait. Very Low Battery," leave it plugged in. This charges the iPhone 4 enough to be able to restore. If the iPhone 4 hangs on this screen for long periods of time, you may need a new battery.
Force restore mode
If your iPhone 4 is hanging with an Apple logo, or exhibiting some other software problem that prevents iTunes from recognizing it, you can force it into recovery/restore mode and then use iTunes to restore the software.
If the device is powered off, plug one end of your USB cable into the iPhone 4 and leave the other end disconnected. Press down on the Home button, and keep holding it down while you plug the USB cable into your computer. After 5-10 seconds, you should see a "Please Connect to iTunes" image on the iPhone 4, and iTunes should prompt you to restore the software; follow the prompts and the instructions given above.
If the device is powered on, hold down both the power and home buttons until the device reboots and displays the "Connect to iTunes" image (generally, 5-15 seconds).
God bless you
May 24, 2013 | Nokia 7610 Supernova Cell Phone
Updating and Restoring iPhone Software
Step 1:
Connect to iTunes
Step 2:
Select "Restore from Back up" and follow the wizard.
Step 3:
Once the phone is restored, click on "check for updates". If the phone requires an update, iTunes will will prompt you to start the update process.
Dec 09, 2012 | Apple iPhone 4 Black Smartphone
I already asked aquestion but solution didn't work. I got a computerfrom my sister-n-law and everything is setup with a user name and I tried to delete user name and now com says............. User's...
Boot into recovery mode from GRUB menu, at the prompt, change user password again to something easy to remember.
passwd user
Then, change the ownership/permission of /home/user/.dmrc to you won't get that error/ignore message the next time you log in.
chown user:user /home/user/.dmrc
chmod 644 /home/user/.dmrc
Now reboot.
shutdown -r now
Mar 05, 2011 | MSI Wind U100-030US Laptop
Wount stay connected when i click on the net it goes off
1.Powercycle your equipment (Unplug the power for 15 seconds then plug back in)
2.Ensure Ethernet cords are plugged in tight.
3.Open Network Connections XP:Start/Run/Type ncpa.cpl hit ok
Vista/7 Start/Search Bar/Type ncpa.cpl
4.Right click on Wireless connection (Router) hit properties
5.Uncheck Internet Protocol Version 6 /Click on Internet Protocol Version 4 and hit Properties.
6.Ensure obtain ip address is marked as Automatic
Ensure obtain DNS servic is marked as Automatic if not check both boxes and close out
7.Disable Firewalls XP:Start/Control Panel/Switch to classic view/Windows Firewall/Turn off
you can access the firewall through control panel with Vista/7
8.Open Command Prompt Windows XP:Start/Run/Type cmd hit ok
Vista/7 Start/All Programs/Accessories/Right click on Command Prompt and hit Run as Administrator.
9.Type: netsh int ip reset reset.log Hit Enter after each Command
Type: netsh int ip delete arpcache
Type: netsh winsock reset
Type: ipconfig /flushdns
10.Restart the computer if this does not work update the Firmware on your router to do so:
Open Browser in address bar type 192.168.2.1 this will bring you to your routers configuration bottom left hand side (Update Filmware) if you are still having issues with it disconnecting refer to Manufactorer
Nov 23, 2010 | Belkin Basic Wireless Router
I just updated to 3.1 why dont I have mms now?
Have you updated your carrier settings? Also a restart is need once all that has been done.
Sep 25, 2009 | Apple iPhone 3G
I downloaded updates on my iPhone 3G, did a reset as required after downloading updates and now my iPhone wont charge, I press the on button top right even hold it for 10sec with and without home button...
Held the home button and power button for 10sec, released the power button after apple icon appeared and continued to hold the home button until the USB cable icon appeared (this action prepares the iPhone for Factory reset), now connect iPhone to iTunes and follow the prompts! Note: when you restore your iPhone everything will be deleted to Factory Settings and you will only be able to retrieve your settings to the most recent back up you have stored, any data not stored in iTunes, example: (SMS, appointments in Calender), will be lost!
Sep 02, 2009 | Apple iPhone 3G
Screen without icons ?
I had this problem briefly. I had to restore my iphone back to factory settings, and the icons and everything came back. Now, it will also update to version 1.1.4.
Mar 09, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
53 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
