You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
This might put the PS3 on order.
Good luck
hi, it won't let me get to the recovery screen, tried all that above, after i do all that it doesn't even ask me to put in or connect usb cable, it goes straight to cannot start the correct hard disc was not found. i'm really stuck, please help me i don't have enough money to get a another.
i can't get into any menu's
if that be the case, you can try this:
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Take care.
Your HARD DRIVE (aka: Hard Disk),
located on the left side of the unit, has crashed. You will need to
replace the HD.
When you replace your hard drive, you
will need to have the latest firmware on a
usb stick. Download the firmware from
the playstation official website onto a usb
stick. Once prompted by your system you
will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
