FixYa.com
Tags:
Acer AL718 17 in. Flat Panel LCD Monitor
Monitor won't come on
posted by bamagrumpy on May 10, 2008
Monitor won't power on.
Comment by bamagrumpy, posted on May 10, 2008
Just a question will a monitor's light come on just plugged into the electrical outlet without being hooked up to a pc or does it have to be installed to a pc to turn on?
Thanks that's what I figured. Will try it tomorrow hooked up to pc.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
RobLW
Rank:Master Master
Rating: 82%, 10 votes
It depends on the monitor, but usually a monitor's power light will come on if it is plugged into the mains. All the monitors I've used will power up to orange light with just the power supply, then once a signal is received from an active PC the light will change color to green.
All the monitors I've used can also be powered off and on with either a touch switch, toggle switch or push switch though, and if the switch is set wrongly then the power light may not come on.
Rating Locked! (?) bamagrumpy has rated this solution as Helpful
Solution #2
Thanks for Trying (70)
marked
Rank:Wiz Wiz
Rating: 80%, 88 votes
Check the power cable of the monitor make sure everything is properly connected.
Comment by marked, posted on May 10, 2008
It will lit up, if there's power button on your monitor press it.
you're welcome...
Rating Locked! (?) bamagrumpy has rated this solution as Thanks for Trying
Can you Help with these Monitors problems?
Monitors
22" flatron (W2252TQ)...
I have two problems. I was... Answer This...
Monitors
broken pins in monitor cable
I broke off a pin by accident... Answer This...
Monitors
Dead Monitor
Hi, I bought my parents an HP... Answer This...
Monitors
monitor isn't working!
At first, there was a hazy... Answer This...
Monitors
SERVICES MOOD OF CRT MONITOR
how to get services mood of... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
