My phone line is ok as i have sent and recived phone call using a plain ordinary telephone however i cant send or recive faxs. if anyone has any ideas i would be greatful
    Genius:
  • 1,218 Answers
If your fax machine has a handset pick up the handset and see if you get "dial-tone" thro the handset of the Fax machine. If you don't then you may have lost the (NCU) pcb, You should always install a fax machine on a "surge-protector" to protect both the Hydro and the Fax line. **The silly thing to check is to make sure the fax line is being plugged into the "line" plug on the back of your machine.
Posted on Sep 02, 2010
The fax can not recive fax just sending it
Is your line fax enable? If not, definitely you cannot receive fax just sending only. Check you telephone provider.
Mar 09, 2011 | Lexmark F4270 Plain Paper Inkjet Fax
Unable 2 send or recive fax
Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 15, 2010 | Brother MFC-8220 Fax
Cannot send out fax
can you copy? If you can't copy then the light has probably failed on the fax reader, or you may be putting the fax in the wrong way round!
If copying works, then check that it is picking up a line and sending, if you lift a phone whilst the fax is being sent you should hear a sort of musical digital tone sound (for perhaps half a minute).
Mar 07, 2010 | Brother IntelliFax-2820 Laser Fax
I have a hp fax 1010 problems sending receiving
Are you plugging the phone line into the line jack or the phone jack on the fax machine, it should plug in to line. Also try and unplug/replug the units power cord as well as trying a different phone jack location.
Mar 25, 2009 | HP 1010 Plain Paper Inkjet Fax
I have brother all in one 420cn. Can send fax but cant recive fax
There are no digital fax machines. You need an analog phone line for your machine to work reliably.
Feb 25, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Send and receive
Most likely has a problem with the fax PCB board inside it. Its not worth repair.
Jan 07, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Cant recive fax
Ok - phone off hook is a message on the printer because you are on the phone. There is a phone that is up somewhere in your home that it can recognize. You cannot send a fax or receive and be on the phone at the same time. This can also be caused by credit card machines, internet service (filter needs to be on fax line), and other fax machines.
To the original poster - your question is fairly vague. This hp link solves the most common issues when you can send but not receive.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01503742&lc=en&dlc=en&cc=us&lang=en&rule=21569&product=391182
Sep 09, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Reciving afax
My fax is on tel.mode. how do i change to auto recieve fax.
Thanks
brendanbuck
Jan 10, 2008 | Panasonic Panafax UF-333 Plain Paper...
Send or recived fax
1st of all do check that the telephone line cord is plugged into the correct jack in the machine. It needs to be in the jack marked "line." not the jack marked "Tel."
Further questions need to be addressed, such as :Is this a recently acquired machine? or Has the machine been disconnected from the power for any length of time? or Has the machine been moved to a different location?
Dec 21, 2007 | Canon LaserClass 9000L Plain Paper Fax
Can I use this fax on a telephone line together with a GE 2.4 GHz Cordless Telephone (Model 27992B)? Will it be possible to recive messages and faxes when no one is at home? Remark: The answering machine...
sure u can: Installation with an answering machine and/or extension telephone: 1. Remove the seal covering the TEL. SET jack on the rear of the fax. Connect an extension telephone or answering machine to the TEL. SET jack. 2. If desired, connect an extension phone to the answering machine. from the user Fax guide: If desired,you can also connect an answering machine or an extension telephone to your fax. ¨ Connecting an answering machine to the fax will allow you to receive both voice and fax messages on the same line while you are out. For details on using this feature, see Chapter 7. (Note: Do not connect an answering machine to your fax if you will be using the distinctive ring feature described in Chapter 2.) ¨ You can connect an extension phone to the fax to make and receive calls like any other extension phone on your line.
Oct 09, 2005 | Sharp UX 510 Plain Paper Thermal transfer...
jasbo
jasbo
