I purchased a Kenmore Elite Washer and Dryer in 2005. Model numbers are 110.66924500 for the dryer and 110.26924500 for the washer. What does King Size capacity equate to in cu.ft? I can't find it in any of the accompanying handbooks or on the machines themselves.
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
You can probably find this on line. If not start with a smaller load and see how well it washes, then increase as you feel comfortable. typically our towel load size at home is 8 lbs. your King size may take a few more.
I would NOT recommend any comforters or quilts, for the 3 to $5 it will cost you at the laundromat it beats breaking your washer at home $$$.
where is control board located
can you stack them and still put a 10 inch pedistal underneith ?
