I have an error message stating the printer doesn't recognize the print cartridge. I installed a new color and two new black cartridges - all three were official Canon 30 & 31. They have been installed propery and the protective tape has been removed.
  • 2 more comments
  • drcarolyn Sep 02, 2010
    I tried it twice. The resume button stayed yellow, it never turned green. However, the powed button stayed green.
    Hi!
    The printer didn't beep when I turned it back on and held the power button; however, I did hold the power button down for quite some time and it still isn't working properly. When it turns on the resume button is blinking yellow, when I try to print a doc I get a message stating it doesn't recognize the cartridge.
    Hi.
    Did you recieve my reply about the printer not beeping when I hit the power button after turning it back on after unplugging it? The problem is still not resolved.
  • drcarolyn Sep 03, 2010
    HI Drifter,
    I tried the solution. The printer is still not recognizing the ink cartridges. The message says they are not installed properly. This happened origionally - then they message stating it did not recognize the cartridges came up when I try to print again. The cartridges are installed propery - I've installed new official Canaon cartridges numerous times on this printer.
    When the printer comes on the yellow reset button is flashing, when I push it the green start up button comes on for a monent then the yellow reset button starts flashing again and the green start up button is off.
    Thanks!
  • 3,247 Answers
Sometimes in this situation it is helpful to re-install the printer driver on your computer. Can't give you the instructions as I don't know what computer or operating system you have.
Please post a comment if you want further help on this.
Posted on Sep 03, 2010
  • 4,924 Answers
If they are not seen you will have to reset it ..to do that unplug the printer..keep the power button pressed and replug the printer ..while you press that button (the start button ..for 10 sec) ..than press 4 times the resume button ..and it will reset itself..
  • 6,993 Answers
Hello
Follow the below steps in order to clear the error:
1.With printer OFF press and hold resume
2.while holding it down push and hold Power button
3.Release resume whilst still holding down power, the light should be green (not flashing)
4.Push resume once (orange) twice (Green)and a third time (orange)
5.release power button.
6.Then power it off and on again after it's finished making any noises and settled down.
Good luck.
Posted on Sep 02, 2010
  • Walesarumi
    Walesarumi Sep 02, 2010
    You can try resetting the printer if the first solution doesn't solve the problem:
    1, Power off the printer
    2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
    3, Hold the Power button for 6 Beeps
    4, Release the Power Button
    This will reset the printer and might resolve error problem.
    Take care.
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
My printer lights ( all three) are blinking with error message of "cartridge problem" I have tried to replace the cartridge with no success and cleaning the cartridge but no luck. Please help.
In this case you will need two new cartridges to identify the problem.
Take one new color cartridge and one black. Now, remove both the old cartridges and install the new ones and restart the printer.
Most probably your issue should be resolved.
Please ensure that you are using the following cartridges only.
Print cartridge information Part name Part description Product number Print cartridge Black HP No. 15 (equivalent to HP C6615 series) Print cartridge Tri-color HP No. 78 (equivalent to C6578 series)
Apr 08, 2011 | HP DeskJet 920c InkJet Printer
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
Can I operate my HP v40xi without a color cartridge?
I would like to inform you that there is no way to print with black cartridge alone. You need to install two cartridges to wok the printer. So I recommend you to install color cartridge and change the settings to print in black only.
May 22, 2009 | HP OfficeJet V40xi InkJet Printer
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Cartridge Error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    12 people viewed this question
    k24674
