Question about Elements Of Design EVWC320 EcoFlush Close Coupled Toilet, White
I have an ecoflush toilet and it keeps "hissing" or what sounds like running, seems to be corrected by lifting the handle up but now it's getting worse and running louder after flushing. Noise again seems to be coming from the clear box that is on the other side of the handle...
    Problem Solver:
  • 8 Answers
Replace inner components or check for trash inside fill vave.. or replace with a toto
Posted on Sep 03, 2010
The two springs in the flush control valve is too weak. I replaced the springs with a slightly heavier gauge and this remedied the problem on six problematic toilets in my hospital. You can also coil a slightly smaller spring to the existing ones and that does the trick.
Posted on Jan 25, 2011
Hissing concealed cistern
The float valve needs adjusted or replaced.
Nov 30, 2014 | Kohler Home
Ecoflush Model B8104 toilet leaks from handle when flushing.
The manual and troubleshooting information is here. This is a plumbing feature I have never come across before.
https://wdiecoflush.files.wordpress.com/2013/05/b8104-service-manual.pdf
Amazon will sell you a replacement module;
http://www.amazon.com/EcoFlush-B8104-Pressure-Assisted-Control/dp/B00FHB8CAM
Jan 06, 2013 | Home
Toilet loosing water in tank. Makes little hissing noise.
the little hissing noise is probably the valve slowly filling the tank back up and the water leaking out is probably because the flapper ball needs replaced. You can see it and get to it and replace it very easily, it is the black ball in the bottom of the tank, it has a chain going from it to the flush handle.
First make sure the chain has not flipped over the handle or gotten twisted, I have seen this happen and it does not allow the flapper ball to go all the way down and seat.
If you rub you finger across the top of the flapper ball and black (deteriorated rubber) comes off then replace the flapper ball, remove the clip from the handle, lift the fubber ears of the flapper ball off of the plastic posts at the base of the bowl fill tube, and replace making sure that there is not to much slack in the new chain, just adjust the clip on the new chain where there is just enough so that the new ball seats.
Make sure you turn the water off to the toilet before you replace the flapper ball your valve in the tank will open to fill the tank and it will run until you get a new flapper in place.
You can het a new flapper for a few bucks at Lowes, Ace, even Wal-mart
Mar 13, 2011 | Caroma Home
Internal leak
I am not familiar with this particular toilet, but most toilets that have a tank have this problem when the rubber flap stopper does not seal and allows water to trickle through.
this is the rubber stopper that lifts when you use the flush handle, the fix was to use the handle and allow all the water to flow out and use a soft rag and clean the area that the stopper seals to, and you will also want to clean the stopper of any gunk that may have accumulated on it.
Mar 12, 2010 | Neptune FB1623 Toscane Toilet
Water disappears to below the bowl inlet and stop.
adjust the float up to make water deeper....make sure no obstructions around the flapper....flapper needs to rest tight to bottom of inside the tank..flapper is the rubber peice that lifts when you push handle
Nov 17, 2009 | American Standard Cadet 3 Right Height...
Water level in bowl too hogh
Try bendig the float rod down so th resivor dont fill so much
Oct 19, 2009 | Elements Of Design EVWC320 EcoFlush Close...
Hissing sound in tank (fill valve) . fills too level line & keeps then slowly fills too top, floats been adjusted .
Dear Sir,
It appears you need to adjust the float level so that it applys more pressure quickly to completely shut off the water going into the main filler tube. Does the hissing go away when you lift up on the float toward the ceiling? If it does, then you need to what I said above. Turn your float ball out farther, or carefully bend your rod down toward the base of the toilet so that it applies more pressure quickly. This should solve your issue.
Cro Dave
Oct 18, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
The toilet sometimes will continue to run after flushing
the chain should have some slack to it being too tight it dose let the flapper sit properly so itll keep running because water is escaping
Jul 03, 2009 | Danco 89448A Universal Toilet Tank Lever,...
Elements Of Design EVWC320 EcoFlush Close Coupled Toilet, White Logo
1,444 people viewed this question
Top Elements Of Design Home Experts
Donni Steen
Tom Chichester
Are you an Elements Of Design Home Expert? Answer questions, earn points and help others
