Question about Magellan RoadMate 1400 Car GPS Receiver
My magellan roadmate 1420 won't turn on. It was working fine, but then when I went to turn it off I think I went too far and pushed it to reset (which has happened before without any problems). I went to turn it back on immediately after, but now it will not turn on at all, even when plugged in
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
  • 9 Answers
SOURCE: My Magellan Roadmate won't turn on
THere is nothing wrong with it. On the left side of the unit pull up the rubber cover. You will see a very small switch and a button above it or below it.
With a a pen slid the switch, and push the re set button. Then slid the switch back. and turn on the unit the way you normally do. If it doesn't light up
either you did it wrong, the unit is discharged, or there is something wrong with it. If nothing works call Magellan and if it is still under service, they will help you. Good luck to you.
Posted on Jan 22, 2009
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
  • 1111 Answers
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
Posted on Jun 15, 2009
  • 1111 Answers
SOURCE: Need Magellan Roadmate 1420 Instruction Manual to download
magellan 1400 usa manual.
http://www.magellangps.com/assets/manuals/roadmate_1400_manual_en.pdf
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
May 24, 2009 | Magellan RoadMate 1400 Car GPS Receiver
The roadmate will NOT turn on; it's "dead" I pushed reset-no response
I had same issue with another Magellan unit. Not good idea to buy from them
Apr 14, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan roadmate 1412
Try the reset button on the side above the plug in.
Jan 14, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Power problem
is there a reset button you can press? if not try charging it for 10 mins then try and turn it on
Dec 29, 2008 | Magellan RoadMate 300 GPS Receiver
Dec 27, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan Roadmate 760
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
Frozen screen on Magellan RoadMate 2200T
Press the button to turn it off but hold it for about 10 seconds. Let go and then press it to turn it on. This resets it.
May 22, 2008 | Magellan RoadMate 2200T GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Magellan RoadMate 1400 Car GPS Receiver Logo
491 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
