Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer does not defrost, builds up alot of ice to thepoint door is hard to open.
  • Amana Master
  • 8,220 Answers
It is probably going to be a bad defrost heater or defrost jeater terminator thermostat.freezer does not defrost, builds up alot of ice to - b816000.jpgfbddf1c.jpgof course it might be the defrost control11e7f93.jpg
AMANA BOTTOM MOUNT MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 02, 2010
  • Dan Webster
    Dan Webster Sep 02, 2010
    If your model has a timerit could be hung up in run mode.
The bottom of my Panasonic frig freezer NR-B29SG2 keeps forming ice making it difficult to open the bottom drawer
Confirm that the seal around the door is tight.
Confirm that the door is fully closed with no obstructions and the door alignment is correct.
Confirm no ice between door and seal.
Using a strip of paper test the tension between the door and seal around the door.
Check the freezer temperature.
It is possible that the defrost cycle has stopped operating. Usually the self defrost will prohibit proper cooling as the ice builds up on the cooling coils. Look for ice build up on the cooling coils/vent openings.
Check the freezer and refrigerator temperatures.
Hope this has helped?
Nov 07, 2016 | Panasonic Refrigerators
I left the bottom freezer of my 650 ajar and when I returned the unit was producing a loud buzz - presumably a motor or fan. It turns off if I pull the shelf that contains the ice tray forward.
When the door is left open alot of condensation forms in your fridge which freezes and ices up. This build-up will gather around your evaporator fan which sometimes stops it from working or sometimes the fan blades scrape on the ice built up.
Best to manually defrost your freezer. Empty your freezer. Turn fridge off. Put a pot of boiling water and close the door. Leave for some time to defrost the ice. You can repeat this a couple of times to defrost the ice. Otherwise you can use a blow-dryer as well.
When you defrost, and turn your fridge back on. Everything should go back to normal.
Ash
Sep 18, 2011 | Sub-Zero 650 / O Bottom Freezer...
Refrigeartor not chilling, freezer not freezing
If you have built up ice inside the freezer walls, and the defrost assembly isn't functioning, this could be the problem.
Defrost the unit! Take all the food out of the freezer side, remove shelves; remove inside back panel. If there is a lot of ice build up there, then your defrost assembly is not working or your refrigerator is not a frost free unit. Defrost either by leaving the freezer door open over night or you can speed the process up with a hair dryer. Once the ice build up is dealt with, you can plug the refrigerator back in and see if it will now freeze the freezer and chill the refrigerator. If it does, and you have a defrost assembly you need to order it and have it on hand when the ice builds up again.
Jun 05, 2011 | Refrigerators
I have a GE Profile PFSF5NJWA has alot of frost building up in the freezer. After a while, the fridge makes a loud humming noise at which point I have to clean out all of the ice to get it to stop. However...
you have a defrost problem the defrost system consist of three things a defrost control, a defrost t-stat and a defrost heater it's hard to say which one of the three it is without checking it with a meter
Nov 20, 2010 | GE Refrigerators
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
I have an LG LFC21770 refrigerator and have noticed a build up of ice on the back wall of the freezer section. Yesterday, when I opened it to get some ice - the ice was frozen but had obviously melted...
If the freezer fails to defrost you get ice building up at the back of the freezer.
The defrost cycle relies in a thermistor transducer to detect the ice build up and to turn on the defrost cycle. The water usually then drips down to a tray under te fridge and then gets evaporated away.
Hopefully you only have a problem with the thermistor and not the defrost circuitry,
This is hard for a repair man to diagnose as when you call them out to your fridge it will be impossible to diagnose if the freezer is totally packed with ice.
And if you let it defrost totally it will be hard to diagnose as they may not be allowed to use freon to cool the transducer.'
So if you call someone in to check this you need to know if the ice build up will be a problem for them .
Youtube has several videos on this situation .
Apr 21, 2017 | LG LFC21760 Bottom Freezer French Door...
My subzero 601 F freezer door gets hard to open unless you wait 4 minutes. While investigating this I discovered that there is a buildup of ice in the trough behind the icemaker. It appears that the drain...
switch off machine. open doors an manually defrost.clean any filters/drain holes(wire is not heated,pull/push to clean pipe)dry as best you can.switch on again.it is best to manually defrost any unit every 6 months and if temp edjustable adjust to -20c for optimum economy.water to icemaker is not important on 601f but is on some others.be carefull
Feb 06, 2010 | Freezers
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator
If the ice build up is only on the back panel of the freezer then you have a defrost problem. Most likely a defrost thermostat or control board/timer. If frost build up is around the walls of the freezer then warm air is getting into the freezer. Most likely cause of this would be gaps in or torn door gasket or door alignment. In some cases the door was left cracked open. If gasket and door alignment is ok remove the frost and see if it comes back.
Oct 05, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
169 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
