posted by martinsc on May 10, 2008
Original problem was TV not operating. To fix this I replaced two 32VDC fuses. I also noticed a ballooned filter cap on another supply. Here is the current problem:
On the outer fringes of the screen the blue is jittery and when its out of alignment (jitter) the blue is further away from the other guns causing blue tinge at the outer edge of the display. The blue misalignment is worst toward the outer edge of the screen.
I can only guess that this was what caused the 32VDC fuse to blow. Any help is appreciated.
Suggest a new solution for this problem
Post a New problem for Projection Televisions
Email this problem
Email this problem
This Problem Also Relates To:
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
Panasonic PT-50LC13 50 in. Rear Projection HDTV Television
Panasonic PT-51HX42 51 in. Rear Projection Television
Panasonic PT-47WX42 47 in. Rear Projection Television
Sony Grand WEGA KDF-42WE655 42 in. Rear Projection HDTV Television
Sony Grand WEGA KDF-50WE655 50 in. Rear Projection HDTV Television
Sony Grand WEGA KDF-55WF655 36 in. Rear Projection HDTV Television
Can you Help with these Projection Televisions problems?
Repair Service
Find Projection TV Repairman Near You:
