Question about Rowenta Irons
My rowenta iron need the power cord replace model de 634
DiYerTech
  • 70 Answers
SOURCE: Rowenta model DE-833 Serie C
Sounds like you need to open the iron up and look for a loose hose/clamp or crack around brass nipple to steam/water reservoir connections. If it has been leaking for some time, there may be some water deposits to help you find the leak(s).
Rowenta typically uses multi-point security Torx fasteners that may be obtained at Kragen's or Harbor Freight tools for a decent price for most DIYers. Make sure to make plenty of sketches to make it easy to reassemble and inspect everything so it is safe to use. Please keep in touch and hope this helps.
Posted on Jul 26, 2008
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Posted on Jul 31, 2008
SOURCE: wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at chuxbizAThotmail.com, just replace the AT with @.
Thanks,
Chuck Jones
Posted on May 30, 2009
  • 43 Answers
SOURCE: Rowenta model dm 860 loose power cord
Most high end appliances (like Rowenta Irons) are made so repairs like that can be done. I haven't played with that model, but I did replace a cord on my Norelco. The torx screwdrivers you are looking for can be purchased, and are often found at either specialty electronic stores (not the average Radio Shack), automotive stores and quite readily online. They are also known as Torx Security bits or Torx Safety bits. Most appliances are made with those screws to prevent the average person from having a go at trying to fix it, but, if you feel comfortable enough with the electronics (even just to look for a loose connection), the bits are available and usually at a fairly decent price.
Posted on Jul 22, 2009
  • 19 Answers
SOURCE: shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Posted on Aug 16, 2009
Where can I get replacement parts for Rowenta irons?
Fixya is unable to advise parts sources.
Aug 15, 2017 | Irons
I have an older (1997) Rowenta DE 11 Powerglide iron. In the process of cleaning it, I mixed up the order of the wires. The colors are brown with the power cord, dark blue with the power cord, blue by...
If you can take a sharp picture of the circuit board and send it jodamechanical@aol.com I might be able to help you.
P.S. Make sure all wires and circuit board are clear.
Feb 10, 2011 | Rowenta Powerglide DE011 Iron with Auto...
Iron cuts off in the middle of ironing
It is probably an intermittent cord connection next to the strain relief. You can simply remove the back cover, cut the cord, pull the remaining cord (approx 6-8") and reconnect it. You can also order part # RS-DE 245954 the whole cord assembly including the circuit board for about $25.
Apr 17, 2010 | Rowenta Irons
Jul 22, 2009 | Rowenta Irons
My grandson knocked my Rowena Iron model DE-87.1b
go to the store get a 2 part epoxy glue follow the directions and mix the glue put it on both the knob and the part the knob goes on wait untill the glue gets tacky then put the knob back on wait 24 hrs. before you use the iron so that the glue can set
Apr 24, 2009 | Rowenta Irons
Wiring diagram for Rowenta DE-05
Thanks,
Chuck Jones
Apr 12, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Rowenta problem
mY de 87.1C WAS WORKING AN ABOUT TWENTY MINUTES OF IRONING, THE CORD & PLUG IN BLEW & IT QUIT.
Dec 26, 2008 | Rowenta Professional DE871 Iron
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Irons Logo
85 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
