Question about Acer Aspire 5100 Notebook
Internet yes its wireless and it bt home hub the laptop is acer
  • Rick White
    Rick White May 11, 2010
    I think we need some more information. Are you having trouble connecting your laptop to your wireless network? What model number is your Acer laptop?
Problem with wireless connection to Acer Aspire 5100. Is there a step by step instructions to connect? A manuel of some sort?
Posted on May 14, 2008
How do i get a user manual for my Lenovo tablet please
Everything is available online these days, or with BT you pay them a fee and they come and do it for you.
Lenovo User Guide
http://www.lenovo.com/shop/americas/content/user_guides/tptablet_ug_en.pdf
And your BT Hub details are here.
http://bt.custhelp.com/app/answers/detail/a_id/46549/~/bt-home-hub-5-%7C-bt
BT Home Hub 5 BT
Apr 03, 2016 | Computers & Internet
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
Hi, I have an acer aspire 5535 and I am experiencing problems connecting to my TP-LINK router. After resetting the router and my laptop I can occasionally connect to the internet, however after a period...
Had similar problem with a kindle and BT home hub - had to manually change the wireless channel on the router but couldn't get a channel that worked when the microwave oven kicked in.
I had two kindles and 2 home hubs and came to the conclusion that some devices must be slightly our of calibration and will struggle to connect on certain channels especially if there are near by routers.
In the end I changed my BT router for a Linksys and its been fine since.
Feb 25, 2013 | Acer Aspire 5535-5050 Notebook
Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have just bought 2 Acer aspire one netbooks. Before Xmas I checked that these would connect wirelesly to internet and they both did - have now tried again after Xmas and they wont connect wirelessly...
Hello, Vicki.
A drained battery would have no bearing on wireless access.
Since both laptops do not access wirelessly, sounds like as issue with your hub. Try the laptops at a wi-fi cafe to see if they work OK.
Hope this helps.
Dec 28, 2009 | Acer Aspire One PC Notebook
Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Feb 06, 2009 | Acer Computers & Internet
Wireless connection problem
BT is right, the fault is at your end, because you can connect to the Internet with an ethernet cable.
You have lost your wireless connection with the wireless hub.
This could be low signal strength (especially if the wireless access point is in one part of the house and your laptop is in another room)
OR Your laptop wireless card has lost its wireless access configuration.
Check your laptop wireless configuration, check your signal strength, check your SSID, check your security (WEP or WAP),
Have you got MAC address filtering.
Go to control panel, click on network connections, right click on Wireless Network, Click on repair (might fix your connection problem), Else right click on Status (should give you indication of how your wireless is functioning or not functioning).
Check your TCP/IP settings is set for "Obtain an IP address automatically"
Without more information it is difficult to identify exactly what is wrong with your connection.
May 11, 2008 | Acer Aspire 5100 Notebook
Xbox360 connection
Yes, you are able to connect your 360 using a hardwired connection. In fact, it is even faster that way!
Your BT Home Hub has two ethernet jacks on it, for use with whatever devices you wish to connect to the internet (in this case, your 360). Simply plug your 360's ethernet cable into the jack, and voila! You can now access Live. However, if you wish to host games over live, you may need to open up certain ports for Live to use.
The ports are listed at: http://support.microsoft.com/kb/908874
A manual for using and setting up your BT Home Hub is at:
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=16536
Near the bottom of the page is a link for the PDF version of the manual.
Jan 01, 2008 | Video Game Consoles & Games
Acer Aspire 5100 Notebook Logo
213 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
