I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF cards & performed a hard reset to no avail. I do have a HP ipaq hp2210 pocket PC & the CF cards work ok in this. Can you help? Regards, Derek Collings
  • 20 Answers
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
Posted on May 10, 2008
Unlock code hp hx2795b
If you mean the hdd or system is locked, contact the manufacturer with the code and they may be able to help.
Oct 29, 2016 | HP Computers & Internet
Hp back files on card can my computer restore these
The Hx 4700 series and the & The Hx2190 have a removable card Compact Flash or SD Card, if the information you want was stored on these you can buy a USB Card reader from woolies plug the SD or Compact flash into the card reader and plug it into the USB port of your PC or mac and it will be readable (no drivers needed). You may also be interested to know that there are updated ROMS available for this model to update the OS & the Office Apps + increase the max capacity of the storage cards that are recognized.
Mar 29, 2014 | HP iPAQ HX4700 Pocket PC
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
Charging pin of my ipaq damaged
hi
I can fix your sync&charge connector very fast in our lab.
you can send your device to us and we will charge you by paypal and return it to you in less than one week.
thanks
Gery
ipaq Lab
Nov 27, 2008 | HP iPAQ hw6515 Pocket PC
Ipaq hx2190
hard reset for hx2190
Jun 27, 2008 | HP iPAQ hx2190 Pocket PC
Media Player won't read storage card library
I gave up and bought ($23) Conduit's Pocket Player which has no problem seeing and reading my MMC card which I sync to from Media Player on my PC through the PC's card reader. Job done!
Liz
May 24, 2008 | HP iPAQ HX2490 Pocket PC
HP ipaq hx 2000 pocket PC
It could be, or it could be something to do with configuration. I researched this earlier, and this CF card problem is something that has come up for several years now, on several different devices, but usually with the Windows OS 2003 or later. Here's a basic summary of the recommendations I found :
- Soft reset the device, using the reset button (on the hx2000 series, that's recessed on the left side of the bottom of the device, and you can press it with the stylus). This sometimes solves the problem, but you will often find that it recurs afterwards. It's more of a short term fix than a permanent one.
- Back up the CF card's data, then reformat it and make sure that it is FAT32. This is the most universally recognized file format and has the least problems.
- If this doesn't work, then a last resort option would be to try backing up your device's software and performing a hard reset to return the device to its factory defaults. Make sure you have everything you want backed up before you do this, though, as it will lose all programs and files that you don't have stored. To perform a hard reset on the hx2000 series :
2. While holding the buttons, press the stylus against the soft reset button and hold it there for about seconds.
3. Once the screen begins to fade, first release the Calendar and iTask buttons, then release the stylus from the reset button. (If you hold all three for more than two seconds, the device will disconnect itself from the battery and power off - apparently if this happens you can simply push the reset button again, or you can plug it into an AC adapter.)
The device should now begin to restart. After this, you need to select to restore the factory settings. Go to Start --> Programs --> File Explorer --> My Device, then open the iPaq File Store. In there, select all files, and then delete them.
If this doesn't work after restoring it to the factory defaults, then I think you may well be stuck with a faulty flash slot. However, let's hope it doesn't come to that - good luck with resolving this problem!
May 11, 2008 | Computers & Internet
Biometric fingerprint
In my iPAQ 2790 , I found an icon in SETTING ( HP Protect-Tools) that help to configure the security in your devise.
Mar 22, 2008 | HP iPAQ HX2790 Pocket PC
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
