Question about Canon EOS-AE-1 35mm SLR Camera
I have a Canon AE-1 SLR camera for my high school photo class and it was working fine but all of a sudden my film advance lever locked and now it wont take any pictures, does anyone know how to fix this?
  • kakima Sep 02, 2010
    Is the shutter button locked? If so, turn the lever around the shutter button to the A position to unlock it.
    Problem Solver:
  • 12 Answers
This may not be the problem, but could it be that you've run out of film. The end of the film is attached to the 35mm film canister. When you run out of film it will prevent the advance level from moving.
Posted on Sep 03, 2010
Advance lever is stuck. I bought new film and a new battery for my canon ae-1, loaded the new film, and took two shots until the frame counter read 1. the next day I advanced the film and when i pressed...
Like all AE-1's and related models, your camera is gumming up inside as the internal lubricant films are at least 25 years old and are largely dried-out.
The fix is to get the camera to a repair specialist for a CLA service (Clean, Lubricate, Adjust). As a one-off extra cost also get the foam light seals and foam mirror buffer replaced as they'll either be absent by now or will still be turning to a sticky goo. Modern foam is is different material and is will not decay like the old stuff.
A CLA and foam replacement definitely costs more than the residual value of the camera, but they're solidly built and have plenty of cheap high quality lenses so can still achieve results which compare well to even the best modern pro dSLR's. Get the work done and your camera will probably last until 35mm film ceases to be available. Your camera will also withstand conditions which you'd never dare risk a dSLR in.
Jun 27, 2011 | Canon EOS-AE-1 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AE-1 SLR film Advance lever does not work
Mechanical problem that must be repaired by a technician. It may be time to retire this camera.
Oct 04, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Sep 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae-1
To open the back pull on the rewind knob ( pulling up ) until back opens. Check that your 6 volt battery is ok ( ae -1 has an electronic shutter so will not work without a battery ): battery situated on the left hand side of the camera ( if it is facing you ) underneath small flip up door ( lock is at the bottom on the left of the small door ) . Check the battery by pressing the shutter release gently and seeing if your light meter needle moves. No movement ? replace battery. You have two modes for taking pictures : auto which is actually AV ( aperture priority) or full manual : both are set by moving the shutter speed dial on the top right hand side ( underneath film winding lever ).
Sep 16, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
183 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
