Question about ASUS P5K Deluxe/WiFi-AP, iP35, S 775, PCI-E , DDR2 1066/667/800, SATA II, SATA RAID, ATX Motherboard
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
System set up on top of box to test. Power supply, memory, Display card, Moniter system speaker, CPU Heat sink and fan, System fan, power switch in place. Push switch:,Power supply,system fan, Cpu fan all start up.Green led led light on MB on. Monitor green led blinking. Black screen no flashing curser, no post no nothing. All connections checked, Card re set, memory re set. Tried different memory, different Display card no luck. I am growing old trying to make this work.. help Al
  • oldal May 10, 2008
    The monitor is cert moniter probably 6 or so years old. And you are correct about the different pin placements. However sorry to say no good result using a new LCD monitor or a cert with different pin placement.The :LCD mpnitor came up with a no signal message. The manual says that The mother board supports an Athlon XP processor With Quanti Speed data processing. The CPU I am using is a Athllon 27648 says nothing about XP, maybe that is a problem? Thanks oldal
Good day! i have 2 x 1 GB kingston memory 533Mhz..can i use it on this motherboard?
thanks
Posted on May 15, 2008
  • 58 Answers
If this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
Posted on May 10, 2008
I have a intel dual core 3ghz cpu my mother board is Intel DG41RQ main board when on my computer the CPU fan is running but no display i check the CPU & ram and monitor that works fine on...
hello there
it seems that your on-board video card having trouble, try to put external video card to your system and power up your computer.
thanks.
Mar 01, 2011 | Gigabyte GA-M61P-S3 Motherboard
L4S5MG/651+ P4 mother board, no display on power
Hi jayson_rees,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Dec 04, 2009 | EliteGroup L4S5MG/651+ Motherboard
I have a rdx200 mother board w/4lights on
Unfortunately, as it sounds like a definite video problem, and the rdx200 has no onboard video, you will need to purchase a cheap test video card to test. I would look to newegg.com for a cheap PCI video card, just enough to get video on the board. you can then begin your testing.
Once you've obtained a cheap video card, if it boots and you receive video you at least know it is not the board itself. If you still get no video, the likelihood is you'll be purchasing a new motherboard for your system.
If you do get video, and you've had the system for only a year, it should still be under warranty. Check with the company you bought the system from for warranty and RMA (return merchandise authorization) procedures.
Nov 23, 2009 | DFI LANParty UT RDX200 CF-DR Motherboard
Comp does not turn on. green light off but goes on when mobo disconnected
Test the power supply in another computer.
If that works, the next thing is to check the mother board. Remove all daughter boards from the slots. Remove all memory, disconnect all hard drives, cdroms, etc.
Make sure there is nothing plugged into the mother board except the video cable (if it is on-board video), if not, then make sure you have a good video card plugged in.
Again with no memory, no boards except a video card, if needed, and the power plugged into the board.
Turn on the power, and watch the screen. If it works, then you should get a notice that there is no memory, no hard drive, and so on.
If that is the case, then proceed to install one item at a time to isolate the problem. If it is not the case, the the mother board is probably bad. One other thing to check would be the CPU.
If you get no notice with the above, then the cpu could be bad. Check it in another computer, if possible. This should tell you what the problems are or is.
In the above cases, either the cpu or the mother board can be isolated to see what is bad, if any.
Oct 07, 2009 | HP Computers & Internet
Compaq Presario v5000 desktop
Is there a power switch on the back of the power supply which is not on? Make sure the power cord is good and plugged into a good power source. Do the fans run inside the system? Is the fan for the power supply working? If not the power supply could be bad. You can purchase a power supply tester to plug the mother board connector into to verify the operation for about $15.00. Do you see any lights on the mother board and the Hard Drive light flickering? If you do and your Key Board lights are on your video controller or monitor could be setup wrong or defective. If the power supply tests good then you need to test the memory and CPU. You could also carefully remove all boards except the video card, mother board and memory and see if it boots up.
Mar 30, 2009 | Compaq Computers & Internet
THE SCREEN SMEARS NAD SHUTS DOWN
Hi eakesj:
A number of things here should be checked.
First shut down and remove all cards, and power connections to all the drives such as cdroms, hard drives.
The power supply should also be looked at and tested for correct voltages on each wire. This can be done with a voltage meter.
Turn on the power and see if you can get the machine to start to the bios screen. (this will work if you have a video processor on board, if you have a video card, you will need it to use the monitor).
If that will not work, then you have more problems than you thought at the beginning.
If the mother board will not work at this point, then you have problems with either the mother board or the cpu processor. There is a possibility that there are problems with the memory modules.
So, if you have only one memory module, then I would remove the memory, carefully clean the contacts, (a clean pencil eraser can work, if you are careful, and do not press very hard) and then plug the memory back in and try again. Also if you have extra modules of the same type, try one for testing.
If you are still having the same problems, then the mother board or the cpu is the problem. At this point you should consider if you want to continue and repair or buy another mother board of the same size. If you buy another kind of mother board, remember you will have to re-install your operating system over the original one to get the complete setup and the bios to work correctly with it. Many times this can be done, but you risk losing data (you will lose all data in MY DOCUMENTS), and may have to completely re-install the OS. You may want to install the drive in another computer as a slave and back up any data you want to save before you proceed.
If you decide to continue with your original mother board, and still have problems, then the cpu or the mother board is suspect. To test the cpu, either test your board with another cpu which is compatible, or check the mother board with another mother board of the same exact model.
Hope you find the problem.
Feb 03, 2009 | eMachines T6534 PC Desktop
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
Please help me!
Hi:
These two may not be the same problem.
As another has said, the first one could be CMOS problem. Get to the cmos by hitting del. on most machines, some use other keys, make sure you watch it closely as it turns on, and hit the key.
See what the settings are. If the settings are ok, then go on to test, if not suspect the battery. Replace it and set the bios/cmos to the settings preferred.
Second one....
You said it turned off. Suspect the following:
Power supply, CPU or fan or both, possible other causes such as hard drive.
Usually the ram would not cause a problem like this...you would at least have some power at the mother board or fans.
You can try this.
The power switch can be a problem here. Test the power switch to see if it is good. One way to do that is to disconnect it from the mother board or remove it from the case, and use an ohm meter to test it(with the power off of course). Some power switches are hooked directly to the power supply. You can remove the power switch from the case, then short the two wires to try to start the system, if that does not work, then it probably is not the switch.
Remove all pc cards from the mother board. unplug any fans, and the hard drive/s, except the cpu fan...we need that.
Only the power supply should be connected, then try, if nothing, continue to test.
See if the computer will turn on. If it turns on, then you need to test each item one by one to see where the computer will not start. The reason I say this, is that all the later power supplies will detect when a short or problem with a component happens. The power supply built in protection will not allow the system to start at all. However, you may hear a very small click or the fans may move a little bit, that is only if there is a problem somewhere in the system when all is hooked up.
Try another power supply, if you can get another one, pref. to borrow or use one you have around.
Examine all cables going to the mother board. Check that they are plugged in correctly, especially the power cables.
One thing here that can stop a computer is a bad CPU, or connections which are not right, that is they could have come loose. What you can try is to carefully remove the CPU (make sure you know how, and how to replace it) examine it on top and underneath. If the CPU had thermal compound on the surface, you may have to clean it and then replace new compound. You can carefully clean the top and the fan heat sink with rubbing alcohol, then dry it, and place new compound on it before putting back.
If so far nothing still is working, then you need to see if the CPU is good. Have a friend or use another computer to test it. If the CPU is good, continue.
If you are still having problems, the mother board may have a problem, such as a burnt out chip or other component.
These test options should get you to find the problems.
Sep 01, 2008 | EliteGroup PT800CE-A Motherboard
No start up , button lites up - cd-rom wont open , noticed no fans on for 3d card or big one on mother board
If the cpu/heatsink fan isn't turning then most pc's will shut down to avoid further damage to cpu & board. I would first replace the fan if it's the one over your cpu. Try replacing power supply. If your board has the 4 pin plug, you must have that plugged in. But keep in mind if that fan isn't running a new power supply isn't going to make it start working. You have to have that fan working. Then go from there. If once it is working & other devices like video and/or roms aren't, check your memory. The best way to troubleshoot devices are to plug one at a time in and power up until the problem starts. Hopefully you won't have to go to that step.
Aug 14, 2008 | E-Machines eMachines Desktop PC
Pc starts and runs but wont boot up monitor shows no signal
1) When you turn on the computer, watch and listen for:
a) power supply fan, (power is on)
b) chassis lights (power is on)
c) ticking sound during memory test
(the BIOS POST is running)
d) beeps or rhythmical error codes
(POST failed, bad CPU, CHIP set, memory or video)
e) Monitor either comes on, displays garbled video,
displays a No Sync or No Signal message...
No depending on how far it gets:
Check power supply, cables etc.
Check video cable.
Check monitor with a different PC
Now unplug the power cord, with the computer still
on, this will help drain any internal capacitors.
Wait 5 minutes, then shut off the switches,
and open up the box. try the following,
one at a time:
2) Remove all I/O cards except the video card,
and don't plug them back in until the problem
is fixed. Unplug all the ribbon cables from
the mother board as well:
Hard drives, CD drive, floppies etc.
Make sure you make notes about how to plug it
back in, and cable orientation !!!
0) Re-seat all power cables: Red, Black Yellow harnesses.
1) Unplug and re-seat the video card
2) Similarly, re-seat all memory SIM/DIM modules,
3) Re-seat the CPU
4) Replace the video card
5) Replace memory, CPU or whole mother board,
Plug the good parts back in one at a time,
and test the machine.
Save for the power supply, there really is NO way to test
and isolate a bad module except by swapping/ trial and error
because of inter-dependencies.
For example a bad I/O card, any I/O card, can short circuit
the I/O bus, causing all other plug-in cards to stop working,
or even the main mother-board to freeze during the POST.
A bad power supply ditto.
A bad memory chip ... ditto.
The type of electronic instruments required to actually
test modern computers running at Gigahertz speed cost
hundreds of thousands of dollars, some cost millions, and
are only available to hi end manufacturers
Even the power supply will not power up for a voltage check
if the mother board is bad, although you can use a jumper
on the green wire to ground to force it on, when you unplug
the power connector from the mother-board, if you are brave.
Computer shops carry a lot of spare parts, and their service
department has gutted computers rigged up as test jigs.
They trouble shoot your system by either plugging your
stuff into their jigs, one at a time, or by plugging known
good components into your computer until the problem
is fixed.
This if of course possibly dangerous, since one bad part
can also fry other good parts that plug into it, or that it
plugs into. The compute shops, of course charge you
enough to make up for this.
If a computer is partially operable, it is also possible to
run software diagnostics.
If not, swap and pray is the only way.
Hope this helps
Please rate my answers, martin.
Jun 25, 2008 | HP Computers & Internet
ASUS P5K Deluxe/WiFi-AP, iP35, S 775, PCI-E , DDR2 1066/667/800, SATA II, SATA RAID, ATX Motherboard Logo
395 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
